Trick to rescue data from a dying HDD ..
Discussion in 'SSDs & Data Storage' started by Cov, Aug 2, 2013.
  1. Cov
    Cov Gawd
    917
    Dec 3, 2007
    Hi,
    I'm not affected (yet), but I have come across the following information and I just wonder if anyone has actually tried this out:
    source
  2. evilsofa
    evilsofa [H]ardForum Junkie
    10,078
    Jan 1, 2007
    Freezing a hard drive will permanently damage it due to condensation, whether or not you put it in a ziplock bag, and does nothing to even temporarily fix the drive, despite anecdotal reports of users who have no idea what they are doing:
    Much more reliable source
  3. YeuEmMaiMai
    YeuEmMaiMai [H]ardForum Junkie
    15,029
    Jun 11, 2004
    I've only seen it work once and once it croaked, it was gone. It is much easier to blast the chips with freeezing spray when trying to find a thermal failure.
  4. Old Hippie
    Old Hippie [H]ardness Supreme
    6,013
    Oct 31, 2005
    It will work on occasion for MECHANICAL HD problems.
    If you can't determine between mechanical and/or data corruption don't bother.
  5. staticlag
    staticlag [H]ard|Gawd
    1,675
    Mar 26, 2010
    One weird trick....
  6. patrickdk
    patrickdk Gawd
    744
    Jan 3, 2012
    it all depends on the issues yes.
    Always attempt to recover as much as possible first.
    I have mounted large heatsinks/fans onto drives to cool them, sometimes helps recover data, mechanical/bearing issues.
    The freezer trick, has helped me sometimes, but I only attempt this, after I write the drive off as completely failed, and don't attempt to recover any more data. I would not deep freeze the drive though.
  7. jojo69
    jojo69 [H]ardForum Junkie
    10,395
    Sep 13, 2009
    this, I have had it unstick a mechanical issue long enough to access the drive one last time
    it is a last ditch strategy but it does sometimes work
  8. Cov
    Cov Gawd
    917
    Dec 3, 2007
    interesting, .. thanks all for your input.
    Hopefully mechanical hard drives are going to be replaced by non-mechanical sometimes soon.
  9. J Macker
    J Macker [H]ardForum Junkie
    10,001
    Jan 25, 2001
    I've frozen a hard drive for 20 mins before. It worked long enough to get the data off.
  10. patrickdk
    patrickdk Gawd
    744
    Jan 3, 2012
    non-mechanical can be a worse issue to attempt recovery :)
    On a mechanical disk, atleast you can do a logic board swap and give it a shot. but that isn't something you can do on an ssd.
  11. Cheetoz
    Cheetoz [H]ard|Gawd
    1,972
    Mar 3, 2003
    Yep, I did it multiple times (on the same drive months in-between)
  12. Shockey
    Shockey [H]ard|Gawd
    1,992
    Nov 24, 2008
    I've also heard of someone doing this with a hard drive in raid 5 to recover the array Shocked it worked but it did. :eek:
  13. soulwatch5
    soulwatch5 n00b
    62
    Jan 15, 2013
    That's a pretty cool trick. Good to know if I ever need to recover data on one of my old drives. As a last resort kind of thing.
  14. d50man
    d50man W[H]iskey Lover
    2,743
    Jan 22, 2002
    click of death is which type of failure?
  15. bbenz33
    bbenz33 Limp Gawd
    382
    Dec 8, 2004
    Click of death is a mechanical failure and is one failure that I have had limited but some success with using this technique to recover data. I was able to freeze the drive pull some data and repeat until most of the data was recovered. As for the person that stated it will permanently damage the drive, I would say that I have not had any issues with it doing that as one of the drives that I performed this trick on actually continued to work "flawlessly" (I noticed no issues) for a while after this. I only continued to use it for a few weeks out of curiousity and once that was over I replaced the drive. However, I will say this is an extremely last resort solution if you don't want to fork over the money to have a professional pull the data off of it.
  16. DPI
    DPI Nitpick Police
    10,960
    Apr 20, 2013
    No hopefully people start making backups. If it can store data, nonmechanical or otherwise it can fail. If it uses electricity it can fail/fry.
