Triangles In Photoshop?
JOKER_JOKER
Quick question. How does one create a triangle in Photoshop? I know it's in the odd shapes category, but I can seem to be able to select it for editing. Is there something where I can create a triangle, and change it's angles, to make virtually any kind of triangle?
neeyo
Use the pen tool and the grid as a guide. Save the path and then you can move each anchor point around to make it any type of triangle you want.
LunchboX3904
Make a triangle with the custom shape tool and then select it with the Direct Selection tool, then you should have 3 points and be able to edit the traingle any way you want :)
