Trendnet unveils 1.3Gbps wireless router using 802.11ac spec
Discussion in 'Networking & Security' started by AMD_Gamer, Jan 9, 2012.
  1. AMD_Gamer
    AMD_Gamer [H]ard as it Gets
    18,275
    Jan 20, 2002
  2. CrimsonKnight13
    CrimsonKnight13 Lord Stabington of [H]ard|Fortress
    7,039
    Jan 8, 2008
    802.11ac is definitely [H] level :)
    DO WANT
  3. Godmachine
    Godmachine [H]ardForum Junkie
    10,472
    Apr 7, 2003
    OMG I want that so bad :eek:
    I just upgraded to 150/35 internet...
  4. Nate7311
    Nate7311 2[H]4U
    3,312
    Jan 11, 2001
    It's going to be years before that's the primary spec. .11ac is a 5Ghz Spectrum tech and after the big push for .11n in the enterprise and personal devices, nobody is going to be anxious to re-buy tech for a while yet.
  5. Godmachine
    10,472
    Apr 7, 2003
    From the sound of it ..
    It should be put through faster actually than N took. I can't wait for it , more speed for wireless in the 5Ghz spectrum is always welcome.
    I hope one day I can just use wireless entirely and not have to spend a fortune to get a solid signal and throughput.
  6. SpaceHonkey
    SpaceHonkey Gawd
    983
    Jan 25, 2007
    As long as everyone has the same goal it will be an eternal problem. There is only so much spectrum to go around...
  7. Adam
    Adam [H]ard|Gawd
    1,592
    Jan 9, 2003
    Heres the big question: Will this be available in the united states??? I didnt read the article but i know the US has some strict guidelines with wireless space
  8. Brak710
    Brak710 [H]ard|Gawd
    1,424
    Oct 27, 2008
    It's unlicensed spectrum, it's the same thing as the 802.11n stuff.
  9. Red Falcon
    Red Falcon [H]ardForum Junkie
    9,865
    May 7, 2007
    Awesome, can't wait until it's out.
  10. Red Squirrel
    Red Squirrel [H]ardForum Junkie
    9,211
    Nov 29, 2009
    It's awesome, the only con is that you get cancer within 15 years of being exposed to it. :D
    That's insane to be pushing that much bandwidth over wireless though. Quite an accomplishment. 10gbit better start getting more affordable. Wireless can't be faster than wired! I did not run all that cat6 for nothing. :D
  11. maw
    maw [H]ardness Supreme
    4,131
    Sep 27, 2000
    1.3Gbps. Max. range, 3 feet. ::p
  12. Red Falcon
    9,865
    May 7, 2007
    Oh I hope not, that would be so lame.
    As long as the distance is equal to that of 802.11b/g with those speeds, I'll be happy.
  13. Godmachine
    10,472
    Apr 7, 2003
    Even if it runs at half speed , it'll still be fast enough for my new connection speed and that is majorly sexy to me.
    I don't transfer tons of files across my own internal network so I would prefer to go completely wireless .. but nothing up til now has be able to do the trick.
  14. Javelin3o4
    Javelin3o4 Gawd
    717
    Aug 19, 2004
    only if you live in california though. :D
  15. valve1138
    valve1138 [H]ardForum Junkie
    10,073
    Apr 14, 2003
    I heard if you aim your coffee maker the right way it makes random files appear on your desktop.
  16. Cmustang87
    Cmustang87 [H]ardness Supreme
    4,405
    Oct 4, 2007
    Man speaks truth.
