tankman1989
- Aug 21, 2009
I have a device that "needs" to be on my network to report usage/stats of various devices on the home power grid. The device uses ethernet over power line (or somethign similar) to talk to the devices in the house, then sends the information to an external webserver via the home network (cat5). The landlord requires this to report on these "smart" devices.
I have had hundreds of issues with 20-30 computers (all have same common issues, freeze ups, strange graphics/pixilation (large pixels) type display on freeze up, and other strange reboots which try to access random HD's on boot) I've also had issues with all the routers (5 different units + 3 home made linux routers) that all have had unexplained problems.
I had isolated the device on it's own network on a Linux router and things seemed to be ok for a while then the router started having problem after problem, so - well, IDK..
So I want to put a computer in between the router and "smart device" to do packet capture or whatever is best to see if there is something strange with this device - or if problems stop when this is put in place.
I'm wondering if a laptop can be used with a USB adapter to give an extra CAT5 port. I can run Linux on it with no problem.
I've looked at wireshark, nexsus, tcp dump, and a few others but they seem a little daunting at first but I'm wiling to learn to figure this out.
Can anyone give suggestions here? I was thinking of installing Kali or an old BT release as I think those have the needed software to do this.
