Tower or mid-tower with a ton of USB ports?
Discussion in 'Cases & Case Modding' started by Morlock, Aug 6, 2019.
  1. Morlock
    Morlock Limp Gawd
    469
    Jun 8, 2012
    Anyone want to recommend a mid-tower (or maybe a tower - I've got another foot or so of vertical clearance under my desk, where my case is) with a bunch of usb ports? I'm looking at the manual and it looks like there are 3 USB headers on my mobo, so I'd like to find a case that can utilize as many of them as possible. I have a lot of USB peripherals (mostly external hard drives) and I'm not pleased with the performance of my USB hubs.
    I ran a google search and the first page of results wasn't promising.
  2. Morlock
    Morlock Limp Gawd
    469
    Jun 8, 2012
    Actually, I guess I need advice on how to utilize my mobo headers, since it looks like I'm not going to find a case that will provide me with a bunch of USB ports. Obviously mobos come with all these USB headers for a reason, but I'm not sure what I'm supposed to buy to make use of them. I just bought a USB expansion card, but AFAICT that doesn't use the mobo's headers, but a PCI port.
    Kinda confused...
    Edit: are they just for running the case's front ports?
  3. DrLobotomy
    DrLobotomy [H]ardness Supreme
    5,885
    May 19, 2016
    You can get a case that has several front panel dvd drive slots, then buy the usb faceplates and plug them in to the usb headers.
  4. Morlock
    Morlock Limp Gawd
    469
    Jun 8, 2012
    Oh Hell yes, 5.25" was the extra keyword I needed. Thx doc.
    DrLobotomy likes this.
  5. janas19
    janas19 [H]ard|Gawd
    1,523
    Jan 20, 2012
  6. Aluminum
    Aluminum Gawd
    664
    Sep 18, 2015
    I'd go with real full ports over hubs, OP already said they had some issues with hubs. Most hubs suck for throughput anyways.
    In 5.25" there are several direct connect options including the new type E connector for C:
    https://www.amazon.com/Akasa-InterConnect-Type-C-Panel-Ports/dp/B07KCLY4YB
    https://www.amazon.com/SNANSHI-1-Port-2-Port-Microphone-Desktop/dp/B07RJ2QKRC
    Also a lot of 3.5" options that you can use with an adapter plate in 5.25" if needed. Fewer maximum ports but there are like a dozen variants of dual 3.0 header panels (4 ports) that don't use hub boards.
    threehundredsixftw likes this.
