Totally stuck, volume keeps turning down, tried almost all new hardware and software.
Discussion in 'Computer Audio' started by mikel833, May 3, 2012.
  1. mikel833
    mikel833 n00bie
    31
    Mar 11, 2011
    **update: The issue is resolved when ONLY running on battery (ac adapter unplugged).
    Hey guys,
    I have an HP Pavilion DV7 laptop... The volume slider keeps turning itself all the way down, even as I try to turn it up. Its been happening for a while now. I've tried:
    1.) Completely removed everything attached to the MOBO, only the LCD, DC Jack, RAM and HDD. Issue still persists
    2.) Same as above only added battery, and unplugged the ac adapter and ran off battery. Issue is resolved.
    3.)Plug power back in the issue happens again.
    I tried many combinations of removing and adding hardware components and they all have the same result.
    4.) I update the drivers, then uninstalled and download new drivers. Installed the software and disabled the software. The issue persists
    5.) Tried updating windows and then disabling the sound software along with HP Smart software. Issue persists.
    6.) installed a new HDD and clean installed windows 7 with only the provided drivers. Issue persists
    7.) Replaced the Sound/Smart Media Power panel. Issue Persists
    8.) Changed the RAM. Issue persists.
    9.) Disabled the sound devices in the "Sound" control panel. Issue Persists.
    10.) Flash the BIOS, already has the newest revision so I re-flashed it. Issue Persists.
    11.) Tried switching AC Adapters. issue persists
    12.) Changed DC Jack & AC Charger.
    Can't think of anything else it could be! Anyone have any ideas? thanks!
  2. Sycraft
    Sycraft [H]ardness Supreme
    4,357
    Nov 9, 2006
    Try a different keyboard, maybe the "volume down" key is stuck on yours or something.
  3. mikel833
    mikel833 n00bie
    31
    Mar 11, 2011
    Forgot to add in the OP, that we tried unplugging the keyboard also.
  4. Spazilton
    Spazilton 2[H]4U
    2,806
    Feb 25, 2005
    10-1 Your Ac Adapter is putting out dirty power, try another one. Since you replaced the motherboard that should eliminate a problem with the charging circuit.
    Dirty power plays all sorts of unpredictable havoc on electronics.
    I have a Galaxy S2 that the touch screen refuses to function with a certain AC adapter. Once its changed to a different one it works normally again. Once I took it apart and looked at its output It had a ton of AC ripple.
  5. mikel833
    mikel833 n00bie
    31
    Mar 11, 2011
    Tried another ac adapter, same issue. =(
  6. ShinyFalcon
    ShinyFalcon [H]Lite
    83
    Dec 18, 2008
    If you go into Sound or "Playback devices" and click on "Communications" tab, is "Do nothing" selected?
  7. mikel833
    mikel833 n00bie
    31
    Mar 11, 2011
    There is no communications tab.
  8. mannyman
    mannyman 2[H]4U
    2,856
    Jan 12, 2011
    Did you change the power saving mode?
  9. mikel833
    mikel833 n00bie
    31
    Mar 11, 2011
    Tried the different modes also. No settings relating to audio within them either.
  10. ShinyFalcon
    ShinyFalcon [H]Lite
    83
    Dec 18, 2008
    Screenshot clarification:
    [​IMG]
    If you're suggesting that no sound ever comes out of your laptop while it's on AC power, then I don't know, it might be an internal hardware issue.
  11. mikel833
    mikel833 n00bie
    31
    Mar 11, 2011
    I'm saying that the communications tab doesn't exist. Only the other three.
    No, we get sound on all power modes, but it stops trying to raise itself to max when we unplug AC power.
