98 SNAKE EATER
- May 1, 2003
What do you guys think about this laptop?
Specifications:
Part#: PSP20U-012RJR
Weight: 9.9lbs
CPU: Intel Pentium4 2.8 GHz(800 FSB)
Display: 17"TFT(1440x900 @24bit)
OS: Windows XP Media Center Edition
Memory: 512MB(Max.2GB)
Graphics: NVIDIA GeForce FX Go5600,64MB(installed)
HD: 60GB
Optical Drive: DVD-Multi Drive
Communication: 56K Modem,10/100 LAN,Wireless LAN(802.11a/b)
Ports: 1x LPT,1x VGA,1x S-Video,4x USB,1x 1394,1x PC Card slot,1x SD card slot
Average Battery Life: 2 hour(s)
Dimensions (WxDxH): 16.4" x 11.5" x 1.8"
Manufacturer Warranty: 1 year
Pros?
Cons?
Similar Suggestions?
I might be in the market for a new laptop (if I can't get the screen fixed on my current one) and here's a list of the things I'm looking for....
Large Screen (15.5" or bigger)
60+GB HD
Firewire
DVD Burner
PCMCIA Slots
Good 24/7
Specifications:
Weight: 9.9lbs
HD: 60GB
Pros?
Cons?
60+GB HD
Firewire
DVD Burner
PCMCIA Slots
Good 24/7
