Tor, PeerBlock...DD-WRT Privacy or ?
Discussion in 'Networking & Security' started by SBMongoos, Apr 22, 2011.
  1. SBMongoos
    SBMongoos [H]ard|Gawd
    1,128
    Jul 22, 2001
    I'm sure there is a long list of these sort of apps. Is there one that is "the best" to use?
    Thanks..
  2. Bookmage
    Bookmage Gawd
    665
    Sep 2, 2004
    could you clarify what you're trying to do? "best" is a relative term and knowing what your trying to do would help us give helpful feedback...
    otherwise it just sounds like you don't want anyone to know about your addiction to midget wrestling gambling sites... :-p
  3. Spooony
    Spooony 2[H]4U
    2,073
    Mar 9, 2011
    TOR-->Jondofox
    Screw peerblock use bitthief
  4. SBMongoos
    1,128
    Jul 22, 2001
    Simple privacy when surfing. Not to concerned about "getting away with downloads". But if that's the software to use because it works better then so be it.
  5. SBMongoos
    1,128
    Jul 22, 2001
  6. zero2dash
    zero2dash [H]ardness Supreme
    6,092
    Oct 23, 2007
    PeerBlock will work, you'll have to grab the right lists, leave the HTTP blocking on, and then whitelist trusted sites when you need to.
    One more thing I'd recommend is (if you're using Firefox), grab the BetterPrivacy extension.
  7. SBMongoos
    1,128
    Jul 22, 2001
    What are the right lists?
  8. defuse
    defuse Gawd
    865
    Aug 14, 2002
    bump
  9. SBMongoos
    1,128
    Jul 22, 2001
    I had Peerblock running the other day while running Vuze. Vuze reported a warning and showed me my IP address which I never have happen before. Isn't Peerblock supposed to hide your IP?
  10. gimp
    gimp [H]ardForum Junkie
    9,816
    Jul 25, 2008
    peerblock is essentially just a firewall that blocks IPs/IP ranges based on the lists you're using
  11. SBMongoos
    1,128
    Jul 22, 2001
    Makes sense. Anyway to be completely stealth?
  12. PensFault
    PensFault Limp Gawd
    141
    May 10, 2011
  13. SBMongoos
    1,128
    Jul 22, 2001
    Looks like they list three services that can run under Win7. Which is recommended? Also, are there good free ones? These appear to be pay services.
    Thanks...
  14. MrGuvernment
    MrGuvernment [H]ard as it Gets
    19,159
    Aug 3, 2004
    most are pay services because they filter your IP out through their own, hiding you.
  15. g|aSsJaw
    g|aSsJaw Limp Gawd
    262
    Oct 24, 2003
    Sorry to bump a thread that hasn't had any activity for a couple months, but I didn't think this was worth making a new thread over. I was just wondering if there's someone here who can elaborate a bit on lists for PeerBlock and which ones to use based on what you're doing online. I have always just used the default P2P, Spyware, and Advertising lists and wasn't sure if I should be doing more, if the program is even worth running, etc. Any help would be appreciated.
