Any answer would depend on what you use your PC for.
So that means the 6C / 12T and above probably are not going to help that much for most of your usage.
Are you overclocking?
will the 7700K in 3 months work on the same mobo the 6700k works on ?
Its not a bad idea. It will be slower in most games than the i7 6700K however.
Yeah, KBL isn't coming out for a couple more months on the desktop. Dual core lower power mobile models (4.5W-15W) were launched first.Katy Lake isn't due to be released for 3 months!?
yea well mr no it all...we suggested them cause he doesn't over clock...at least not at this timeDon't know how can anyone say, that best bang for buck is a 5820k or a 6700k for gaming. The 5820k is an enthusiast grade cpu and the 6700k is a high-end mainstream cpu. Neither of those groups could be considered best bang for buck. The higher you go - the more you pay for extra performance.
As mentioned before, for gaming you should probably be looking at non-k i5 cpus or, better yet, at the -k skew cpus and overclock them. When overclocking yelds 20%-30% or more performance and is so easy these days, there really is no reason not to do it.
If your 2500k is not overclocked you should do it now (if mobo supports it) and maybe extend the life of your current system. Waiting for new cpus is usually not worth it. There is always something "coming soon", performance improvements are usually insignificant as well, when it comes to cpus.
I recently sold my 3570k system (close to the 2500k). It was perfectly fine, played all games without maxing out the cpu usage @4.5ghz. I just wanted more threads for some cad rendering and bought a used 5820k.
The only reason to buy an i7 for gaming is if you are doing something in between that can actually use the hyperthreading and/or the extra cores. Most of the games do not do that and, with dx12 reducing the overhead, won't need to do in the near future. So, imo, an overclocked i5 is the sweet spot for gaming and will last you quite a few years again, just like your 2500k.
Even if he doesn't overclock, an i5 will give 90% of performance in games of an i7 for 60% of the price. Recommending an i7 as "best bang for buck" is nearly the same as calling a gtx 1080 "best bang for buck". But, ofc, as always it depends on the person. No need for namecalling...yea well mr no it all...we suggested them cause he doesn't over clock...at least not at this time
Intel Core i7-6700 is probably what you want...with modern intels best bang for buck is stay where your at and or learn about over clocking
sure i agree.....even better over clock it! lol...i was just making a point6700k clocks higher out of the box. Better value.
5820k would do just fine with a decent overclock....of course if ALL you do is games skylake would be a better fit....the extra cores excel at doing actual work like converting blue rays where it smokes a skylake EASILY.....IF your into doing heavy multitasking it makes sense as well....otherwise go with skylake
Coming from a i5 2500k or should I wait until 2018 when the new Intel processors are suppose to come out?
what your describing is not really heavy multitasking...heavy multi tasking would be doing some kind of heavy cpu taskI am a little confused guys. Primetime said this:
So the 5820k is better at heavy multitasking ? Would this help firefox performance if I am worried about that? lol Sorry but I thought maybe it would help a little. I am quite a heavy multitasker or like to think I am.
I normally leave Firefox, email and a lot of other applications open while I am gaming. Does that consider multitasking ? I already got a SSD and enough ram. Maybe that (SSD and ram) helps more or is more important if your a heavy multitasker.
150 or so price difference....but maybe 14nm is worth the extra money?...idk the thing is if you have the correct MB one could always upgrade the cpu down the road. I suspect if you overclock both to 4.4 any cpu bottle neck will be none to minimalng4ever,
I would not consider the 5820K at this point: It has been obsolesced by the new 6800K.
Maybe I'm out of date but I thought that there is hardly any gain going from an i5 to an i7 for gaming purposes?
