Top 5 PPD/Watt Rigs in the [H]orde
4p Magny Cours 6166HE @ 2.025 GHz, Seasonic 650W 80+ Gold PSU, 6903 unit - 383K ppd, 466W, 822 ppd/W
Would love to see the numbers on some of the faster G34 4p's out there to see how good this really is.
My 4p Magny Cours 6172 @ 2.1 GHz turns in 15:15 frame times on a 6903 for 445K ppd. Don't have current power draw info though. My Kill a Watt is being used for another project.
2P x5570 @ 3.2Ghz
310W at the wall
103K PPD on 6903
00:40:23 TPF 6903
333 PPD/W
4p6174@2.475GHz
P6903: 12m48s, 650W at the wall
890 PPD/W
4x6176@2.3 undervolted to 1.05v (520w draw)
458kppd (best week averaged out to ppd)
880ppd/w
2P G34 Extra Sexy Dodecas @3.2ghz/2.4ghz NB
286k PPD (6904 avg)
520W
550 ppd/w
dual x5670
85K PPD
289 watts
295 ppd/W
You should be seeing higher ppd than that with the 3.1ghz turbo folding frequency on those hexes. Make sure you have numa enabled and linux installed so you can get the 6903/6904 units, you should be closer to 130k ppd I would think.
Everything is setup for 6903/4 but I hvae never received one on either box, this is using v7 client. I'm going to reinstall everything put and v6 on the 5640 box and see what that does.
Its amazing how the PPD/Watt has jumped up in the past year.
It really is, what actually changed so much that people are able to get 3 to 4x the PPD/Watt? It seems both Intel and AMD CPUs are able to hit over 800 PPD/Watt now. I'm not the most experienced, but I know Sandy Bridge brought some power saving to the table for Intel, but I'm unsure of what AMD has done that has changed in the last year.
The PPD/Watt change is much more than I expected since 1 year ago.
A lot has to do with the -bigbeta units since then which I get 333 PPD/W. Even on the old bigadv 6900 I still get 200 PPD/W and regular SMP gets me about 129 PPD/W ish. So I really think its a combination of work unit changes, and we may have just become more efficient. There are a lot of tweaks and optimisations that we use such as running native linux with the kraken affinity wrapper. I was not folding a year ago but its still amazing how much the PPD/W has changed even with the same hardware. Even on the same work units with the same hardware we get more points now and it just goes to show how much more effort we put in to maximizing our PPD and lowering power consumption.
Those are very nice chips he has, they have 3.33 Ghz Turbo! (25x Muliplier)
It does seem to be that v7 does not get -bigbeta. Those hexes should be destroying some PPD... My dual x5570 quad cores at 3.2Ghz get 103K PPD on 6903 just for reference. Those X5670's have a 133mhz clock speed advantage and 2 extra cores! They are 4% faster clocked and have 50% more cores so 56% more processing power. I would guess 00:25:52 TPF on 6903 under good conditions which would net you about 201K PPD if my numbers are correct.
Hey I'll take regular -bigadv, it's processed nothing but A3 SMP for the last 3 days!!:eek:
At the time we originally did this, you needed Windows to run bigadv (or Wine in Linux), the SR-2 had just came out (jebo, Kendrak, and Vaulter had the first 3 for the Horde), and hex Xeons and 12-core G34s were well over $1,000 per chip. Some of the big events:
- MIBW showed up with his herd of dual hex SR-2 machines that would have beaten any of the original boxes listed, and did a huge portion of the initial overclocking work for SR-2s.
- The L5640 "extra spicey" chips followed soon afterwards, making dual hex SR-2 rigs a more practical possibility.
- 10e (and I am sure others) figured out how big of an effect NUMA settings in multi-proc boards has
- bigadv came to Linux, and 10e and others showed us what was really possible with the G34 platform with Linux and bigadv.
- We discovered the benefits of the BFS scheduler for 24 or fewer cores
- tear developered The Kraken wrapper - given pseudo NUMA support for the FAH core.
- Stanford released the 6903 and 6904 work units.
- The availability of G34 chips outside of retail outlets increased, making them available to more of us.
These were all big events that have happened in the last year+, and the sum total has lead us to where we are now with the big 48 core machines approaching 900 ppd/W and several dual proc options giving 400+ ppd/W. It has definitely been a fun year!
Good summary musky. This has probably been the biggest year for high end folding in a long time.
My 4P is pulling 550 from the wall.
Current 6903 is 413803 PPD
So ~750 ppd/w
Awesome! That is very informative for people like me who don't pay enough attention to keep up with all the changes :)
BTW good job on your unbuntu folding guide, well organized and very easy to follow. I'm a big fan of putting linux commands in the code tags for readability.
i want to see patriots 4OC'd 4p...
When I have a bum units and am pulling 600k ppd with my 4p... at 915w thats still 655ppd/w non overclocked 4ps typically rank in the 800s ppd/w
Your ppd/w might suffer, but you're still getting more gross ppd than the stock clocked systems.
l5640's, antec tp-T 650w psu, 6903
112k
236w
474 PPD/w
That definitely beats SR-2 ppd/w, seems Intel's engineers were right in assigning such low clocks to the server parts.;)
AMD too. Patriots ppd/w goes to hell when he overclocks too.
Interesting on the L5640 versus X5670 comparison. I would have guess the ppd/W on those to be closer.
that antec PSU is a POS, when i can afford to swap it out i'll plug the killowatt back in and see what its pulling then.
112k
236w
474 PPD/w
X5670's, Corsair Ax-650 PSU, 6903
165k
289w
571 PPD/w
What clocks are these guys running at?
The L5640 looks a little dissappointing (PPD wise not PPD/W :D), and the X5670 seems about right.
My dual X5570's get 104K PPD on 6903
8 x 3.2Ghz = 25.6Ghz, 104K PPD
Your L5640's get 112K PPD
12 x 2.8Ghz = 33.6Ghz, 112K PPD
33.6/25.6 = 1.3125, so your chips have a 31.25% performance advantage over mine.
112,000/104,000 = 1.0769 (rounded down) which is only 7.69% more PPD
Now 12 x 2.26Ghz (Stock L5640 no turbo) = 27.12Ghz
27.12/25.6 = 1.059375 which is 5.9375% faster than my quads
So factoring for the exponential curve, and upload time your L5640 hexes are running at stock! no turbo!
EDIT: The X5670's are 12 x 3.33Ghz = 39.96Ghz, 39.96/25.6 = 1.5609375, 56.09375% faster than my quads.
1.5609375 x 104,000PPD = 162,337.5 PPD
Not sure what your upload times are but it seems the bonus curve is less pronounced here. Are you using HFM estimated points? Thats what I am using for my calculations.
the L5640's are at 2.26 - not sure if they turbo or not, if they do i think its only to 2.4. The x5670's have turbo and they go to 3.2. Since they are both on linux and i hate linux more than jebo does - i'll wait for my new daily driver to arrive and load windows and see what CPU-z is saying about spicy L5640's
Quick maths shows that the L5640's do not turbo but Musky would know as they were his originally.
If they do turbo then the rig is running slow
The spicy chips should be turboing 1x versus the 2x for retail, I haven't seen any that do this differently.
I was going off of:
http://ark.intel.com/products/47926
http://ark.intel.com/products/47920
They do turbo just fine but it's only to 2.6 GHz (x1) when all cores are fully loaded.
If they are turboing then something isn't running right. By my maths
112000/24/2.4 = 1944 PPD per core per ghz. Mulitply that out by the x5670 numbers and I don't get the 165k that the 5670's are currently reporting.
Start with the 165k and do the maths and i should be getting 123k from the L5640's.
I'll have a look tomorrow and see if i can see anything. Is there any similar utility to CU-z on linux that will tell me what everything is currently running at?
I dont think they are Turboing, the numbers work out to them being at stock.
PPD is a non linear function of compute power while your direct comparison computational approach is linear. Your reasoning would work when trying to predict one tpf given another but cannot be applied to ppd. The fact that you get a bigger point increase for added speed than a linear comparison would suggest is Standford's way of rewarding people for upgrading hardware and the crux of the bigadv controversy of the last couple years.
Your rigs are running fine. ;)
