Comixbooks
- Jun 7, 2008
Does he scale to your level? I have like zero time invested into this game =)
Wouldn't surprise me. In any event, he's kicking my ass.
What difficulty are you playing on? I'm play on arcade cos I'm a casual player + noob.
I was still in tier 1 mode and got my ass handed to me by the predator and gave up for the night after 5 deaths.
Edit: got lucky and managed to get a kill.
I just started playing this so I won't be hitting up the Predator just yet.
And here I was thinking I wasn't ever going to get this.
So do you need to buy some new crap to be able to play this mission, how do you even get to it?
Thanks, I found it. No, minigun tho. So I'm not that exited. Do you get any reward for killing it? Seems to be designed to annoy you rather than anything else. I didn't know the predator could teleport. You can hear it running then in 1 second it appears 200m away behind you running in the other direction. Also he's completely invisible both on thermal and night vision.Nope, just fire it up. You get a mission notifier, see the spot on the map, mark it and go.
He's got some tricks he never had in the movies.
Tom Clancy's Ghost Recon Wildlands
^^ Do everything he says to the letter.
^^ I did everything he said except I changed a a couple of the weapons with the idea to completely avoid need to reload because that ammo box is a deathtrap.
I was in thermal the entire time.
It's a frustrating fight to be sure, but I got it thanks to polydoil's tips. Marry yourself to the rock and those two trees SE of that ammo box.
I can't say the prizes are really worth much.
Watch starting around the 45 second mark for a little bit. He shows you what you win. Cosmetic fluff basically and some points and so forth:
That Skin is one Ugly MF
Like speaking english? Doesn't make sense tho.He's got some tricks he never had in the movies.
A good, longtime friend gifted me Wildlands on the 21st. So far I've been having a blast. What is a bit frustrating is I can see a target yet it won't tag it. Range, no matter the weapon or scope seems to be limited to roughly 500 meters. I've had clear LoS on targets as far away as 800 meters. Is there a setting or something I'm missing?
Bullet drop comes into play at range and it is funky how fast the rounds will start to drop off. I would suggest googling the ingame scope + rifle to get a correct Mils reading as many people have already done the maths. Now having said that, the next problem is the draw distance for npcs, for me, if I dont spot and tag with the drone they vanish from sight around 500 to 600 or so meters.
When I played with a friend I was able to see and kill enemies close to him from over 800 meters away, much further away than if I played by myself.
I usually rely a lot more on the binoculars and drone the most for spotting. I played solo.
This really is a good game. I've been chewing away slowly getting my Tier 1 levels up... or I guess "down" since it counts down to 1.
Appreciate the tip but I've been playing FPS shooters for longer than many members here. And, as an FYI, I'm a honorably discharged U.S. Marine. I know very well bullet drop is prevalent.
Binocs nor drone aren't fully upgraded so that may be part of the issue. Seems funny that sniper rifle scopes suffer from the same issue, though. I can only spot targets less than 500 range. I can see them, just not tag them for the AI to kill nor get the range kill myself.
You can't tag them, but you can kill them. You just can't adjust the scope in the game, so you have to aim above them, also It's a good idea to remove the suppressor if you're sniping from that huge distance.
I have killed them at long range. Sniped one at 576 meters (it is in my uPlay profile, AceHoleGoober) without having tagged the Tango first. I just find it odd that tagging (orange or purple circle appears above their head) doesn't occur on ranges longer than 500 meters.
Believe me you, I have no issues hitting a target at greater than 500 meters.
My best kill, so far, has been 480 meters through the tin roof of a building killing a Tango who was sleeping in a cot. Bastard never knew what hit him.
Given your previous post (see my response to it )...are we still talking gaming or in real life?
Dumb question: In real life you can put a suppressor on cannons like the Desert Eagle and such?
