I just purchased the Asrock Z77E-ITX mini board.
I am using a Noctua 92mm PWM CPU fan. It appears that the setting options in the BIOS does not allow my CPU fan to dynamically adjusts the fan speed to address the heat generated by the CPU stepping. When the CPU is idle or full load, the fan speed is the same speed.
I only 2 see options in the BIOS for CPU FAN 1: Full On or Automatic Mode. I have tried both options, but the fan spins at the same speed. My expectation is that when the CPU is idled, the fan spins slow.
So my question: What is the setting to allow the CPU fan to dynamically adjust the fan rotation speed to the heat being produced by the CPU?
thx!
thx!
