Titan XP vs 1080 TI
Discussion in 'Video Cards' started by Orphan Crippler, May 16, 2018.
  1. Orphan Crippler
    Orphan Crippler n00bie
    31
    Feb 5, 2018
    Titan XP worth the $1500 for games
  2. Orddie
    Orddie 2[H]4U
    2,211
    Dec 20, 2010
    i believe in every bench mark it out does the 1080ti. but depends on the work load as to where it will really excel.
    {NG}Fidel likes this.
  3. Dayaks
    Dayaks [H]ardness Supreme
    6,368
    Feb 22, 2012
    Value is in the eye of the beholder.
    Definitely not worth it IMO. Side by side you wouldn’t be able to tell the difference with a 1080ti.
    Chikia12187 likes this.
  4. Chimpee
    Chimpee [H]ard|Gawd
    1,265
    Jul 6, 2015
    For games, nope, definitely not worth the extra cost since they are too close to each other in performance.
  5. misterbobby
    misterbobby 2[H]4U
    3,580
    Mar 18, 2014
    Titan XP is basically same exact performance as the 1080 TI. Now if you're asking about the Titan Xp then simply look at the reviews and you'll see it's only a tiny bit faster than the 1080ti. And a non reference 1080ti would close that gap even more. Not sure why you didn't just do literally a couple of minutes of research first.
  6. Raendor
    Raendor Gawd
    858
    Sep 21, 2015
    Hey guys, the OP post is a statement, so what are you arguing about? Just nod and walk along.
  7. {NG}Fidel
    {NG}Fidel [H]ardness Supreme
    5,646
    Jan 17, 2005
    It is faster by a decent margin. But personally not sure it's worth the jump right now unless you find a good deal.
  8. misterbobby
    misterbobby 2[H]4U
    3,580
    Mar 18, 2014
    The Titan XP is not faster at all. Again though if you're talking about the Titan Xp then yes it's a little bit faster.
    revenant and Armenius like this.
  9. {NG}Fidel
    5,646
    Jan 17, 2005
    Sorry that shit gets confusing but that's exactly what i mean. And honestly you oc the original pascal titan and it can hold its own vs Ti
  10. Shadowed
    Shadowed Limp Gawd
    357
    Mar 21, 2018
    Titan XPP is 12% faster clock for clock. Titan XP also comes with a terrible blower.
    Aftermarket 1080 Ti's are much better in this regard. But as soon as you watercool the Titan, it will outperform by a small margin.
  11. doubletake
    doubletake Gawd
    517
    Apr 27, 2013
    Bobby is wrong too so don't let it get you down. The correct name (regardless of what other people want to call it) is the Nvidia Titan X (not to be confused with the GTX Titan X, which was Maxwell).
    Dayaks and {NG}Fidel like this.
  12. {NG}Fidel
    5,646
    Jan 17, 2005
    I know that its Titan XP - 1080TI - Titan Xp in terms of stock performance but I often fuck it up when talking or writing it because Nvidia did such a shit job with the Titan in the Pascal line (naming and confusion wise).
  13. Shadowed
    Shadowed Limp Gawd
    357
    Mar 21, 2018
    They keep releasing far too many Titan variants per generation.
  14. FlawleZ
    FlawleZ Gawd
    712
    Oct 20, 2010
    It's easier to just use architecture name. Titan Xp = Pascal, 1080Ti = Pascal, Titan X = Maxwell, etc.
    I'd like to see some benchmarks with Titan V (Volta) vs GV100 Quadro
  15. Dayaks
    6,368
    Feb 22, 2012
    There’s two Titan X Pascals. I remember because I blasted the original for not being a full chip. People got defensive for some reason, said I was an idiot and it wasn’t possible, then the fucking full chip came out.
    The Titan line should be dead to gamers since the 1080ti came out. The Titan V isn’t meant for us either.
    Shadowed likes this.
  16. Armenius
    Armenius [H]ardForum Junkie
    15,431
    Jan 28, 2014
    Are you talking about Titan X or Titan Xp? Because there is no "Titan XP."
    1080 Ti = Titan X < Titan Xp
  17. misterbobby
    misterbobby 2[H]4U
    3,580
    Mar 18, 2014
    I know what the cards are actually called. The OP said Titan XP which is what everybody refers to the original Titan X Pascal.
  18. HiryuuX
    HiryuuX Limp Gawd
    208
    Jul 16, 2017
    Negative. The 1080 Ti isn't particularly a great value per dollar, the minimal increase in performance for the XP significantly impacts the price/performance ratio.
    That said, the XP was popular for the Star Wars models which funny enough had crappy Founder's Edition cooling.
  19. Shadowed
    Shadowed Limp Gawd
    357
    Mar 21, 2018
    The annoying part is Nvidia released a Titan X for Maxwell then a Titan X for Pascal. So people called it the Titan XP to differentiate it from the original. Then Nvidia decides to release the full chip and calls it Titan XP just to confuse the situation.
    So I call it Titan XpP ;)
    But whenever someone with little GPU knowledge refers to the Titan, they usually have no idea what architecture it is.
  20. misterbobby
    misterbobby 2[H]4U
    3,580
    Mar 18, 2014
    Have you really not been paying any attention? The Star Wars models were not on the Titan XP, they were on the Titan Xp.
    Armenius, Shadowed and {NG}Fidel like this.
  21. {NG}Fidel
    5,646
    Jan 17, 2005
    Lol we all know what he meant.
    GoldenTiger likes this.
  22. HiryuuX
    HiryuuX Limp Gawd
    208
    Jul 16, 2017
    Lolol ;)
    revenant and GoldenTiger like this.
  23. doubletake
    doubletake Gawd
    517
    Apr 27, 2013
    Just because everyone's doing something doesn't make it right :U
    Armenius likes this.
  24. misterbobby
    misterbobby 2[H]4U
    3,580
    Mar 18, 2014
    Well how about actually paying attention to the context here? The person that started this thread said Titan XP so it's only common sense to use that to differentiate between the first Pascal Titan X and the Titan Xp.
  25. doubletake
    doubletake Gawd
    517
    Apr 27, 2013
    I wasn't replying to OP though
  26. misterbobby
    misterbobby 2[H]4U
    3,580
    Mar 18, 2014
    Are you truly that ignorant? Open your damn eyes and look at the comment that you quoted from me earlier. I was already talking about the OP right there and how calling it the Titan XP was relative because that's what he was calling it. Instead your foolish ass takes part of what I said out of context and then when I quote you on that you turn around and say you're not talking about the OP. Clearly all the hell you're trying to do is start an argument.:rolleyes:
  27. Renato
    Renato n00bie
    32
    May 7, 2018
  28. doubletake
    doubletake Gawd
    517
    Apr 27, 2013
    Damn, I didn't realize you took this so seriously. You spent more effort in that one post than I spent in the last 3 combined lolol
    Sorry if I raised your blood pressure over this, it wasn't my intention. Deep breaths.
    Also, again
    Titan X
  29. misterbobby
    misterbobby 2[H]4U
    3,580
    Mar 18, 2014
    And no one's arguing over what the actual name of the card is and you know it. The point that you seem not to be grasping is that the person starting this thread said Titan XP and that is what people referred to the first Titan X Pascal card especially when trying to differentiate between it and the Titan Xp. It's not 100% clear exactly what card he is talking about so again pull your head out of your ass and look at the context here. And go ahead and knock yourself out with the last reply as I won't be bothering with someone acting as ignorant as you again.
  30. kimura14
    kimura14 n00bie
    31
    Dec 17, 2016
    Titan V worth the $3000 for games, too
    craigdt likes this.
  31. pippenainteasy
    pippenainteasy Limp Gawd
    491
    May 20, 2016
    From a $/perf perspective, actually yes, If you are comparing potential performance (i.e., on water), the Titan V is worth anywhere from $2800-3500 if you extrapolate the extra performance from the $/perf gain from 1080 Ti -> Titan Xp ;D
    kimura14 likes this.
  32. doubletake
    doubletake Gawd
    517
    Apr 27, 2013
    The point that you seem to not be grasping is that I'm 100% aware of what's going on in this thread, just as you appear to be; the main difference is that I don't have a stick up my ass about it.
  33. Crackinjahcs
    Crackinjahcs Limp Gawd
    134
    Jan 31, 2018
    Ordering direct from NVidia, with tax (when they are in stock), for a Titan Xp is about $1330. Not sure where you're getting the $1500 from?
    And as for worth, it depends on your personal financial situation, the rig you're putting it in, the games you play, and at what resolution. The more information you give us the better we can help.
    The Titan Xp is about 5% faster than the 1080ti (according to review by Gamers Nexus). What I found was that in some games the Titan Xp had enough extra juice to get above that 60 FPS break point in some titles at max settings (4k), while the 1080ti was a few frames under. At 1440p with my Titan Xp most games keep my framerate pegged at 144 FPS with just a couple tweaks in the settings.
    Also, when I bought my video card you couldn't reliably find a 1080ti for less than $1300 so in my case why not step up to a Collector's Edition Titan Xp for $1138 + tax? It was worth it for me.
  34. Supercharged_Z06
    Supercharged_Z06 2[H]4U
    2,360
    Nov 13, 2006
    A waterblocked Titan X (Pascal) seems to have a bit more headroom as to overclock ability than a waterblocked 1080Ti. However, with stock blowers, the 1080Ti and the Titan X (Pascal) are pretty much neck and neck as to performance. The Titan Xp is a good 5% faster than both as others have mentioned. All these cards will throttle if pushed hard (OC'ed) on air, so to get consistent, sustained high performance, water cooling really helps.
    Titan V is definitely king as to performance right now, but also ludicrously priced for what it is and the added performance. (+20-25% over a 1080Ti)
    If you can wait a couple months, the next gen cards are supposed to drop. Odds are the "Ti" variant will follow another couple months after that. Right now isn't all that great a time to dump $1300-$1500 into a video card with the new stuff in the chute.
  35. Johnny78
    Johnny78 [H]ard|Gawd
    1,262
    Jan 13, 2007
    I have my Titan Xp watercooled and runs at a stable overclock at just a hair under 2100 mhz. At that speed it's around 10-15% faster that a similarly overclocked 1080ti. If you're using the stock cooler (which is pretty terrible and loud) the lead is probably only around 5% faster than a good AIB 1080ti. Is it worth the price increase? Probably not, but then again these are enthusiast cards and generally speaking, horrible investment tools.
  36. Aireoth
    Aireoth [H]ard|Gawd
    1,990
    Oct 12, 2005
    Titans are only worth it when you buy at launch. Their value is being the fastest card by usually 30% for about 6-8 months before a ti version is launched that runs within 5-10% the speed at half the price.
    After the ti launches it's really not worth the price.
  37. Archaea
    Archaea [H]ardForum Junkie
    8,702
    Oct 19, 2004
    Or when 1080ti are selling for $1200 new due to miners and Titan Xp Star Wars Collectors editions are selling for $1134 new at Nvidia.com
    But overall yeah. A Titan Xp isn’t worth it now. The reference blower is inferior. I recently built one for a customer using an open air Thermaltake p3 Case because the customer only wanted a titan and couldn’t find a normal prices 1080ti. Unfortunately, the Titan Xp was throttling under 3dMark 20 minute stress test and couldn’t pass the 97% required stability stress test due to the thermal throttling. That would never happen with a nice aftermarket cooler option like EVGA ICX or equivalent. I’d rather just have a high end 1080ti with a nice after market cooler , than a Titan Xp that throttles and spins up a noisy fan.
    Crackinjahcs likes this.
  38. Aireoth
    Aireoth [H]ard|Gawd
    1,990
    Oct 12, 2005
    Yeah, but who here living it up H style (which you can do at any price point) leaves a titan stock, I slapped that bitch underwater and now it doesn't go over 50c running at about 2004mhz with a +700 mem clock.
    Though I agree, the ti is the better value overall, and no modding needed to get a better cooler. Plus mining made everything crazy.
  39. Crackinjahcs
    134
    Jan 31, 2018
    My TitanXp was hitting 83°-84° C and throttling under moderate gaming load. After downloading MSI Afterburner and only adjusting the fan profile it runs high 60's/low 70's under heavy load at stock speeds.
  40. melk
    melk Gawd
    908
    Jan 21, 2014
    Bored at work :D
    Kepler
    GeForce GTX TITAN --- GK110-400-A1 --- February 21, 2013
    GeForce GTX TITAN Black --- GK110-430-B1 --- February 18, 2014
    GeForce GTX TITAN Z --- 2× GK110 --- March 25, 2014
    Maxwell
    GeForce GTX TITAN X --- GM200-400 --- March 17, 2015
    Pascal
    GeForce GTX 1080 Ti --- GP102-350-K1-A1 --- March 5, 2017
    Nvidia TITAN X --- GP102-400-A1 --- August 2, 2016
    Nvidia TITAN Xp --- GP102-450-A1 --- April 6, 2017
    Volta
    Nvidia TITAN V --- GV100-400-A1 --- December 7, 2017
    Aireoth likes this.
