So, after checking my previous build thread here:
http://hardforum.com/showthread.php?t=1272877
it looks like I go about 4 years between builds of my main rig. In the meantime, I've built other boxes (an i3 build for my WHS, for example), but now my main rig is really due for replacement (it will continue to exist, but as yet another capable machine for my kids to play on...)
So, onto the 10 questions:
Light gaming, but extensive photo/video work, as well as music production. I'm thinking i7 IB in a few weeks.
Pretty much unlimited, but I don't want to pay any more than I actually have to for what I need. I *do* live near a MicroCenter, so I'm hoping that they run a special on i7 IB cpu/motherboard combos next month...
US, suburb of Philly.
Case, Cpu, Ram, GPU, SSD, DVD, Keyboard/mouse (so, in a nutshell, "everything" )
I already have monitors, that I will be reusing, and I have plenty of "storage" hard drives around, so I'll only need the SSD boot drive for this rig. I *require* an SSD on the order of 250GB.
6) Will you be overclocking?
Yes. I've never done a water cooling rig before, but the prebuilt corsair units really seem simple enough that I'd happily consider it. Which also means the case will need a place to mount the radiator...
2 monitors, both 1920x1200. One landscape, one portrait, but I can't see why that would matter...
As soon as IB is available, but can start buying parts immediately.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support?
USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
RAID, not really, but hard to escape it being available nowadays.
Firewire, yes.
No Crossfire, or SLI is required...I'm a single GPU kind of guy.
USB 3.0, yes.
SATA 6Gb/s, yes.
eSata, yes.
No need for onboard video.
Would like a metric shit-ton of rear USB ports (I currently use about 8 on the rear of my current rig)
Windows 7/64 bit (I'm an MSDN subscriber)
In general, I've always gone with full tower cases, for lots of room, and lots of hard drive space. But, nowadays, I live almost entirely off of my WHS server for storage...So, a single SSD and a single HDD will probably cover me. So, I'm thinking a mid-tower would suffice.
I've learned to like my current Gigabyte MB, so I do have something of a slight inclination toward their products.
I'd like a TON of memory, mostly because it's certainly cheap enough nowadays. 24 or 32gigs.
Oh, here's another question. It's common knowledge that having multiple spindles (HDDs) is beneficial. Is there any reason that the same is true of SSDs? In other words, Is there any benefit to having 2 SDDs instead of one, if they total the same amount of storage (I'm not talking about RAIDing here, at all).
Thanks!
-Kevin
Firewire, yes.
USB 3.0, yes.
SATA 6Gb/s, yes.
eSata, yes.
Thanks!
-Kevin
