Thunderbolt Motherboard Otions
Finny76
Is there any damn Intel Motherboard that supports 8th Gen CPU & has a Thunderbolt Port or capability to add a thunderbolt card?
I know some Gigabyte Z-170 Motherboards came with a Thunderbolt port but none of the Z370 boards have Thunderbolt. I think it should be a common feature being adapted my all manufactures, since its been out for a while now.
If there is something upcoming I would like to know so i can dete4mine how long the wait it.
Aluminum
Did you even look? Here you go: https://www.asrock.com/MB/Intel/Fatal1ty Z370 Gaming-ITXac/index.asp
The TB3 is only on x2 lanes but if you are one of those weirdos trying to do egpu with a desktop for some inane reason I have no sympathy.
There are a handful of asrock and asus atx z370 boards with the 5 pin header requried for expansion cards to work, its somewhat random which models they put it on every generation. You can find it marked on closeups of pcbs or download the pdf manuals.
Vyedmic
Just built an ASUS Z370-A + ASUS ThunderboltEX 3 based system and all is rosy.
