Those With Monoprice LCD Desk Clamp
Tai
Does it have foam protection on the clamp to prevent from damaging the desk and for better grip?
Firefox90
I ordered one Sunday. I'll post up when it arrives. If not, that is an easy fix.
Tai
Thanks Vague, I think I'll spend a lil more to get what I want then. Thank you
Firefox90
I got mine and mounted my 19" LCD on it. For $18 bucks, I can't really complain, but the vertical tilt mechanism isn't the greatest design. If you fiddle with it too much, the display will slip down. I could of used a bit more height too. But for $18 bucks vs. $50+ on other stuff, I'm fine with it.
Oh and I just used a couple sticky foam pads for the mount. Not a big deal.
ghostchild
they look flimsy at first but they work!
22".... will try my 24" tomorrow I've been using this arm for about a year now, no problems after initial setup. I would probably use a rubber washer though.
Firefox90
You mean use a rubber washer on that vertical tilt screw? Have you tried that? Does it improve the screw grip?
Weenis
I said WEENIS, not...
I just got one in the mail, I'm going to set it up tomorrow afternoon with my 24" LG.
I will let you know how it goes, and what possible improvements I can see from it.
I suspect some rubber/foam would be included if not... you can't gripe for $18..
Seeing as Ergotron and HumanScale ones are. oh 150$.. I think we can throw a few bucks at it to get it the way we want it.
I only got one.. if it is good I will get a second for my 20.1" Dell....
Only thing I'm concerned about is I have a 1/2" glass top desk. But I can't really see it being an issue
