PC Surgeon
- Dec 18, 2005
Coming from a flat TV/Monitor do you find the curve brings more immersion? With all things being equal would you prefer curved vs flat? What's your pros/cons after using it?
anyone using curved monitor for coding or excel want to share their experiences ?
Does that mean that you usually have 6 windows open when you code? I don't think that I've used more than 4 windows... yet.![]()
Does the curve help you at all when you are coding?
Most curves are so mild you don't really notice that it is curved.
What are you using it for will change the answers quite a bit I'm guessing.
