If its a crap psu, a good psu will shut down. I recently plugged in a hard drive that had a short in it. Guess what happened, my psu shut down the rails the hdd was using (I could tell as my other mechanical hdd shut down also) and the computer kept running even though the rail the hdd was on was overloaded by a short.
Sorry but if it was designed good it would shut down before it damaged itself. It's not a new concept even cpu's shut down when they reach there limit (thermally, you can still kill them by overvolting). If you make the protective limits bypassable then whats the point still a flawed design.
yes but cpus have a huge amount of resistors, caps and regulators keeping it safe. A gpus thermal throttling are within its drivers as well as the protections.
And a psu can't shut down when its protections is removed that was my point I will go poof. Same as the card
But anyway Nvidia THE WAY ITS MEANT TO EXPLODE <- THey should change their slogan now
