This happens ...
Tony Montana
Printer Lexmark Z600 Series(2) failed to initialize because a suitable Lexmark Z600 Series driver could not be found.
then
The following boot-start or system-start driver(s) failed to load:
Kl1
then my computer crashes and restarts... this started happening 2 days ago after i unisntalled my lexmark software... whats going on any suggestions?
gigabyte1024
I'm not trying to be the cynical a-- hole, but seriously, Lexmark sucks. I've cleaned up after countless fubar printer drivers who think they are gods gift to spooling. They get in deep, make the print spooler service dependant on *THEM* and then choke, wrecking the whole printing subsystem.
Uninstall and hope for the best, then take it back.
Tony Montana
i did un install and it started doing it.... im wondering if i reisntall and just leave it there if it will work?
dbwillis
Maybe the driver software installs some service? try checking services and maybe set the Lexmark one (if its there) to disable
Tony Montana
i have all the lexmark crap uniosntalled and turned off... i disabled the printer spooler service... it all started when i installed acrobat....to make a resume... ill uninstall that too
