QwertyJuan
- Aug 17, 2000
Simply drag the file you use frequently to the Dock and it'll "pin" it there. One can also make Folders or Stacks to contain multiple files and then change the way each container looks when it opens (as a fan, a grid, or a list).
Dropbox and SugarSync aren't built into OS X yet but the person you were responding to seems to have found it easier and more enjoyable to do what he needs to do on a Mac, which is what is going to dictate how much work he does or doesn't get done in a day.
That said, I was happy to move away from half a dozen replicated services and simply use iCloud to sync everything. Now I no longer use Drive, DropBox, or SugarSync, or any of the other myriad other services I have forgotten more of than remember.
For first reply - Can these files be pulled from different locations? As in from different HDD's or network locations?? (honest question).
Second - It "might" be nice to move away from third party apps, but when you work with a bunch of different people, each using another "app" to sync, unfortunately third-party apps are sometimes a necessity.
P.S. I don't see how installing Dropbox on a Mac is any easier/better than installing it on Windows. I've done it many times and it's really tit for tat.
