My case is a Kingwin 424. Was planning on getting Danger Den TDX w/ brass top for cpu, Maze 4 GPU, 10ft Tygon tubing, Typhoon-Quad Dual Reservoir, 2 120mm Pro-120 radiators w/ shroud and 120mm fans, and a Swiftech MCP-600 Pump Rev.II. Problem is I dont believe all this will fit in my current setup.
Was going to go to Homedepot and going to purchase 3/4 alluminum angle, rivets, weather stripping, and 1/8 thick lexan.
Going to construct exterior frame with 3/4" alluminum angle and rivet it together with a 'blind pop-riviter.'
I then used 1/8" thick lexan to for the sides and just cut it to the sizes i needed. Was going to use scrollsaw with a 24TPI or finer blade.
I plan on using weather striping between the alluminum and the lexan to make the box air tight, and then riveted the lexan down on the alluminum.
Going to use two 86' Chevette heatercores equipped with 120mm fans to pull heat from radiator on the two side holes on case and equip a 120mm fan on rear of case.
Was going to have this exterior case underneath my computer case.
How do you think this exterior watercooling case will work? Any ideas or suggestions would be appreciated.
