Hi everyone,
I've had my system up an running for about a month now and I'm quite pleased with everything but my cpu temps. I was going to let it go until I realized tjmax is not 90c as I thought, it's probably more like 100c. I am using ocz freeze thermal paste for gpu cores, chipsets and cpu, ceramique on the gpu ram. My system is in my sig, and these are the max observed temps taken from everest, note this was with a 90c tjmax:
CPU: cores spread between 59c-62c during prime95 for 34 hours, idle 36-39c
GPUs: folding@home seems to put the biggest stress on them, the cores have never passed 48c, idle around 38c
MCP and SPP: throwing some volts at these and yet neither have gone past 41c, idle 35-36c
So this means my cpu load temps were more like 69-72c! I'm seeing about 20 degrees difference from idle to load too, which shouldn't happen with my cooling loop. I've tried both the drop in the middle as per ocz's site and have switched to the line technique as per arctic silver's site. Both the line, and quad insert washer, were oriented correctly. Even though my system is stable I can't help but think that elusive 4ghz would be possible with some lower temps. Thoughts? Thanks!
