TheMadHatterXxX
- Sep 7, 2004
Is there anything substantially better around the same price range ($500) coming out soon? I think I can just re-use my current ram also since it's DDR4.
Nothing concrete. Intel has Alder Lake coming out but nobody knows what kind of performance or pricing were looking at. Then there's rumors that Amd may be refreshing but they are just rumors. So basically if your feeling the need for speed, hit the the gas pedal!Is there anything substantially better around the same price range ($500) coming out soon? I think I can just re-use my current ram also since it's DDR4.
Really? The 5900x seems to be 1.25x better on single core and atleast 2-3x better on multi-core benchmarks.For gaming? Heck no, I honestly don't even notice a difference between a 5900X and my old 8700K. Definitely wait for next gen from both Intel/AMD unless you really have the upgrade itch just to upgrade for fun.
The 8700K was literally the best CPU released a few months after Ryzen first generation came out; I had both systems to compare (Ryzen 1600 vs 8700K) and the difference in price between both was like $200-250 for CPU/MOBO/MEMORY and the 8700K absolutely smoked my Ryzen 1600 in gaming and it still does today. I can barely tell any difference between the 8700K and 5900X today for gaming performance.
The 5900x is a heck of a lot faster by most metrics. The 8700k isn’t a bad cpu but it’s old tech for sure.Really? The 5900x seems to be 1.25x better on single core and atleast 2-3x better on multi-core benchmarks.
Is the 10700k out of reach? In my opinion right now I would reach for the 8core vs the 6core if the price difference isn't a deal breaker. Not familiar with the AMD chips but no 8 core alternative?
I would wait for the Zen 3 refresh with the extra cache. Its supposed to be out December/January. That should be a fair bit faster in gaming, than regular Zen 3. Which would make it fairly substantially faster than an 8700k.Is there anything substantially better around the same price range ($500) coming out soon? I think I can just re-use my current ram also since it's DDR4.
Thanks I will wait for this!I would wait for the Zen 3 refresh with the extra cache. Its supposed to be out December/January. That should be a fair bit faster in gaming, than regular Zen 3. Which would make it fairly substantially faster than an 8700k.
Current CPUs are faster for gaming. But I wouldn't say substantially faster, except for a few edge cases. (certain games do love extra cores. And in general, 8+ cores will help you keep higher minimums, especially at high refresh rates).
Also, with a 2080ti at 1440p, the differences are going to be pretty small, anyway. and almost no difference at 4K.
