Is there a max 20" wide, not much more than 1" thick VESA mountable 22" / 21.5" visible monitor?
Background: my current travel monitor is 19 1/2-inch [49.5 cm] diagonal and 1" thick. The backpack I landed on finally is 51cm high so a 21.5" diagonal is possible. The bigger the better so let's find a monitor that fits. The PHILIPS 223V5LSB is only 19.80" / 503mm wide, LG has a 20.00" / 508mm wide and there are a few more. But, these are 2.0-2.2" inch thick and that is really excessive.
