using nvidia panel? should be set to full screen, perform on gpu and override ticked. if that doesn help, drop to one monitor and see if you can get it full. then add the others back. it could be because of the mismatch monitors.When I set up gpu scaling, full size for each monitor it doesn't expand to the edge. In surround mode it won't let me select gpu scaling
is there any scaling options in the monitors menus? it shouldnt be that card. could be the drivers not working right though. have you ddu'd and updated at all?Disconnected the 2 flat screen and tried it with just the MSI connected to the DP. Was able to get full screen, GPU scaling and checked the box but it still wouldn't expand to the full width of the screen. Might just been the low power 1650.
tool_462 - exactly like that. So the thin bezel is just marketing bs? Was hoping to use in a triple monitor setup with iRacing which is why I bough the thin bezel. Oh well
lol i guess asking for pics might have ended the thread sooner....I assume you mean like the below pic? That's just how monitors are these days with "hidden" bezels that look fancy when they are black or off. I am not aware of any 144hz monitors with true thin bezels. I'm sure they exist but I just haven't seen any.
