Roen
- Aug 7, 2021
There are 3 different bandwidth sub specifications of DP 2.1. Beware of marketing material that just says "DisplayPort 2.1". You should know when / if you actually really need the higher bandwidth sub spec though, see video for details.
View: https://www.youtube.com/watch?v=nIgHNP-9SvY
I'm in no way affiliated with TFT Central nor am I compensated for sharing this video.
I don't see a good reason for UHBR10 to exist so it feels like a future problem being created today just so that manufacturers can abuse the term "DP 2.1" to sell products even though supporting only UHBR10 offers no benefit to the user. One would assume monitor manufacturers will make sure their monitors support at least the bandwitdth they require at max refresh at native resolution, but if they're cheap about it e.g. 10bit RGB may not be available at the highest refresh rates.
Dear future you and me: start by calculating your bandwidth requirements and read the fine print in the specs, looking for UHBR20 or UHBR13.5 as needed. I found a display bandwidth calculator but it doesn't tell you what the number is with DSC applied. So if anyone knows by what percentage(s) DSC compresses signals, please share the info with the rest of us.
Edit: calculator with DSC on LTT forums here.
Edit #2: Quote from displayport.org's FAQ:
How does VESA’s DSC Standard compare to other image compression standards?
Compared to other image compression standards such as JPEG or AVC, etc., DSC achieves visually lossless compression quality at a low compression ratio by using a much simpler codec (coder/decoder) circuit. The typical compression ratio of DSC range from 1:1 to about 3:1 which offers significant benefit in interface data rate reduction. DSC is designed specifically to compress any content type at low compression with excellent results. The simple decoder (typically less than 100k gates) takes very little chip area, which minimizes implementation cost and device power use, and adds no more than one raster scan line (less than 8 usec in a 4K @ 60Hz system) to the display’s throughput latency, an unnoticeable delay for interactive applications.
