buffbiff21
- Sep 27, 2006
OK I plan on buying this for my first setup:
http://www.jab-tech.com/product.php?productid=3264
From what I heard it is the best radiator out there.
Forgive me if this is noobish, but it says 3/8 fitting on the description (and i plan on using 1/2 tubing for everything). Can I just buy barbs that are 1/2 and screw them on there?
Thanks!
Thanks!
