Gutspiller
- Oct 19, 2005
So I'm looking at the Thermaltake Toughpower 850W here: http://www.thermaltake.com/product/Power/ToughPower/W0131/w0131.asp
1. So from their specs it appears to have two 8pin PCI-E and two 6pin PCI-E power connectors right?
2. The "4-pin / 8-pin +12V Power Connector X 1" cable mentioned is the 8pin motherboard power, right?
3. All the cables for this modular PSU can all be connected to the power supply at the same time right?
4. Does anybody here have the Thermaltake Toughpower 850W? Are the bad things about it? If you have this PSU, is the connector clip on the 8pin PCI-E power centered on the end that connects to a video card or is it off centered? I need it to be centered so that it fits into a 9800GX2 card without being shaved.
5. Does anybody know how good the Ultra / X3 / 1000-Watt PSU is? I see it for $233, which seems pretty good for an Ultra, modular, 1000watt power supply. Is there something wrong with this PSU/brand?
Thanks for any comments on these.
