Although I am quite happy with the case I purchases back in November 2007, I am no longer happy with the company who should at least be able to tell me what size fan was used. I will save the story and copy/paste my email that I sent to their support team. My original question is at the bottom, and if anybody can provide ANY help whatsoever, you'll be helping me more than those who get paid by Thermaltake.
Dear Customer,
Thank you for contacting Thermaltake.
You may find parts, refurbished, and discontinued items at http://www.thermaltakeusa.com/store
If they are not on the above site then we do not have them for sale at this time
Have a great day and thank you for choosing Thermaltake.
Best Regards,
Thermaltake USA Customer Service
1-800-988-1088 M-F 9:00AM ~ 5:30PM (P.S.T)
-----OriginalMessage209502-----
Name: Michael Email: mhenley***censored*** Phone: ***censored*** Company: Question / Comment: I own a Thermaltake Armor Series VA8003BWS case, and need a replacement side panel fan. When I purchased it, the link said the side panel was a 25cm fan, but the model number is TT-2230a, which suggests it's actually only 23cm. The largest fan I can find on your site is p/n AF0047 which is listed as a 23cm fan, but my case isn't listed under the compatible cases section, it also shows TT-2020 on the fan label. Will this fan fit in my case? Is my fan 25cm or 23cm?
http://www.thermaltakeusa.com/Product.aspx?C=1441&ID=1955 was the link I was looking at that shows the fan on their website.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133021 is the link that I pulled from my newegg history for my case.
Dear Customer,
Best Regards,
