Thermaltake Core P3 – A Different Kind of Build
Discussion in 'Worklogs' started by David Deyarmin, Mar 11, 2018.
  1. David Deyarmin
    David Deyarmin n00bie
    11
    Mar 11, 2018
    used to build computers in the 90s but then work got in the way so from the early 2000s til just recently I bought off the shelf units for productivity work and some light gaming.
    When my most recent HP AOI died and I bought a simple economy gaming computer to replace it but I had to migrate the guts over to a slim line mid case which meant I had to do some research and I discovered a whole new world of case modding, which reignited my desire to build.
    After looking at builds all over the net I decided I wanted to do something different.
    A lot of builds concentrate on the cooling system or some extravagant themed case.
    I wanted to showcase the actual hardware and I wanted to do it in a balanced minimalist way with the MB and GPU on the front and the power supply and liquid cooling system on the back
    I started with a Thermaltake Core P3 Chassis
    To make this work I had to rotate the chassis 90 degrees and use the back as the front which required a lot of internal and external modifications to the metal chassis
    Final Assembly has begun
  2. David Deyarmin
    11
    Mar 11, 2018
  3. David Deyarmin
    11
    Mar 11, 2018
    spugm1r3, ZeqOBpf6 and shadowlord like this.
  4. David Deyarmin
    11
    Mar 11, 2018
    I guess no one knows what to say about this :)
  5. Spaceninja
    Spaceninja [H]ard|Gawd
    1,745
    Sep 15, 2004
    It does look better that way. I've never cared for the way the PCI-e cards are mounted in that case. Clean mod, I like it.
  6. David Deyarmin
    11
    Mar 11, 2018
    Because of the radical placement of the power supply relative to the mother board I need to shorten one of my power supply harnesses
    I was able to route the ATX and VGA power harnesses without modification but I had to shorten the Mother Board Harness
    All of my cables will be hidden so there was no reason to order a custom shortened harness so I ordered the tools and supplies to do it myself.
    Here are some videos that describe the process
  7. David Deyarmin
    11
    Mar 11, 2018
    I worked on the extra illuminated IO cover for the right side this week end
    Due to the different orientation I had to de-solder the factory wire that connected both covers and then solder a new longer wire in it’s place
    You can also see the 3-D printed bracket parts required to make it work with the right side of the mother board
    I still need to solder a jumper wire to the left cover so I can connect them in parallel that way they will be have equal illumination.
    IO%20Covers%20003_zpsof9qwwvi.jpg [/URL​
    Core%20P3%20007_zpspr8uquxb.jpg [/URL​
    spugm1r3 likes this.
  8. David Deyarmin
    11
    Mar 11, 2018
    I finished the first stage of my build
    I’m still waiting on the 3.5” monitor for the PCI-E Slot Area and I have to fabricate a fan mount for the top but it is far enough along that I can mount it in my cabinet and make it my primary computer
    Here are some other assembly pictures
    Archaea likes this.
  9. Archaea
    Archaea [H]ardForum Junkie
    8,337
    Oct 19, 2004
    That turned out well. I couldn’t see the vision at first - but I like the final product.
  10. David Deyarmin
    11
    Mar 11, 2018
    Thanks
    Some pics with the 3.5" monitor mounted to the MB
  11. spugm1r3
    spugm1r3 [H]ard|Gawd
    1,164
    Sep 28, 2012
    While I love the idea of the monitor (I'm assuming for temps/voltages), I think the monitor glow detracts from the finished product. You have some really excellent balance with the lighting, and I love that you showcased the components, but I'm not in love with the monitor (at least, not in photos).
    Cheers on the novel build!
  12. AwakenedBeing
    AwakenedBeing [H]Lite
    105
    May 23, 2008
    Great work on the build!
