Here are my playas'
Did some testing as well, and I can tell you that there is no difference between regular TRUE- I would call it typical collectors item and this is Thermalrights point as they "stated" that this cooler will be produced in limited amount 3000pcs!
In my testing Black ed. even achieved little better results, but you can probably write off it on mounting- I run those tests twice with remounting Cu ed. and results had the same tendency! Used the same mounting for both coolers and contact were good and difference between cores were within 1-2C
MB: Gigabyte EP35-DS3P (bios F3)
CPU: Intel Core 2 Quad QX6700 @ 3,4Ghz 1.42V & 1,55V
Fans: Gelid Silent case fan 12 PWM @ 1350rpm during tests & SilenX iXterma Pro 120x120x38, 1400rpm, 90CFM , 18DBA (by spec
Thermal grease: Arctic Silver Ceramique
read software: Core Temp 0.96.1
Ambient temp: ~19C
Load: Prime 95 small FTTs
TRUE Black 120
TRUE Copper
Load Prime 95 Small FTT, QX6700 @ 3,4Ghz 1.42V
Load Prime 95 Small FTT, QX6700 @ 3,4Ghz 1.55V
Ambient temp: ~19C
TRUE Black 120
TRUE Copper
