crazycrave
- Mar 31, 2016
It's cheap enough that every Ryzen 5000 should ship with one! cheaper than the $45 RGB Cooler Master cooler that 3700x shipped with!
needs more than that. this is how i paste 5000 series chipsStock settings 5900x, grain sized thermal paste
Bahhhhhneeds more than that. this is how i paste 5000 series chips
Will do - so far so good on lowering my voltage - mind you, I haven't had to do this with any other cooler.Keep up posted. Mine is still sitting in the box awaiting my procrastinating ass to put the Intel box together. Although, mine won't be sitting on a 105w CPU but a 65w one.
I used the whole tube that came with it, took a paper card and spread it over the whole cpu nice and even, as to be more of a paste and not something like that Silver TM5, working great on my 5600x.needs more than that. this is how i paste 5000 series chips
What happened to the "Don't put much more than X" or "you don't need more than Y" days? I thought more thermal paste reduces dissipation. Is the rice sized droplet no longer recommended for any cpu install these days?I used the whole tube that came with it, took a paper card and spread it over the whole cpu nice and even, as to be more of a paste and not something like that Silver TM5, working great on my 5600x.
CPU heat speakers have gotten a lot bigger.What happened to the "Don't put much more than X" or "you don't need more than Y" days? I thought more thermal paste reduces dissipation. Is the rice sized droplet no longer recommended for any cpu install these days?
there is no such thing as too much with an ihs, it will just squish out the excess. there is such a thing as too little where its not matting the surfaces correctly.What happened to the "Don't put much more than X" or "you don't need more than Y" days? I thought more thermal paste reduces dissipation. Is the rice sized droplet no longer recommended for any cpu install these days?
What was your previous AIO?Okay - installed mine tonight -
Jesus this thing is massive - lol
Had just enough depth to fit it.
Compared to an AIO - this thing is quiet AF. 5900x idling between 32 and 35c -
Interestingly, my GPU has seemed to drop a couple of degrees during idle.
Great deal. Thank you all.
Update - the fans that come with the cooler are kind of whiney.
Think I'll put another set in there to keep it all quiet.
I wonder how many have the Rad upside down on a front panel or rear, the lines (piping) always go's on bottom and top of rad tank above cpu pump, this is where all air with coolant lose will go and stay.bought the argb for $39. ehh ill try it out, my 280mm nzxt aio in my daw/video editing pc is too loud, 360mm aio nzxt on my gaming pc is super quiet in comparison.
what brand is it?Sry, forgot to update the thread with pa120se fan noise findings. There's no difference that I can tell between the pa120 and se fans. Both fans are quiet until I cranked them up above 55-60%. The noisemakers in this case are the new 6800xt fans. They have an aggravating low whine/buzz at all ranges. Fortunately they stay off most of the time. Disappointing in a brand new card but the heatsink is gone in a few weeks, so no biggie.
Leo, still doing it wrong, he could turn the computer upside down to correct it.
Its an Asrock phantom gaming D.what brand is it?
Never owned an Asrock product so far, good to know!Its an Asrock phantom gaming D.
I would be interested in you pulling it off and seeing the spread pattern of the paste to determine if it is infact an even spread or if there is a mounting issue. Not saying you did anything wrong but curious. No new paste would be needed as it is so new.Appreciate the update. Been out of the loop. Thanks guys.
Well done, I wasn't able to see the difference in them until you pointed it out! I guess I was too busy trying to keep those fiddlyass clips on long enough to get the fans attached, bleh. Now I finally know what the Thermalright seller meant.View attachment 507108
Here is my 2 minute MS snip tool attempt at showing the fan differences between the Peerless Assassin and Peerless Assassin SE. Left is the standard PA and right is the PASE. I think TR calls the grey fan 'Reverse'. The fins are opposite the PASE blades. Flow is the same, meaning it goes the typical way of fan blade side = intake, which means the PASE fans must spin clockwise - which they do. Most case fans I've used (and as an example all the other fans in my case - 2x Cougar, 2xArtic, 1xNoctua) all spin CCW.
I don't have a standard PA to compare but I'm betting they spin the typical CCW direction.
I find them to be a little bit noisier than I like at 1500 RPM, but to be fair I consider a lot of fans (even my favorite pricey noctua's) to be a little noisy at 1500 RPM. The Noctuas are a little quieter though, so eventually when I stop being lazy I'll try swapping in my pair of Noctua NF-A15s if they'll fit and see what happens.
Fans noise is so subjective so to help give an idea of my personal taste I consider 900-1300 RPM the sweet spot for noise vs flow. Above 1500 and you hear even the best of fans, IMO...
Pea size method is out dated. IHS are to big on current CPUs to be enough. I always sided in the heavy side.Soooo yeah - you were all right.
I pulled off the heatsink and this is what was left behind - pathetic!
View attachment 509618View attachment 509619
I ended up making a H symbol and spread the grease over evenly and WOW - idles are 32c - cinebench barely hit 55c at stock settings
I retract my statement about not being sure about this cooler. It was 100% user error.Now I'm more than sure my AIO wasn't the issue either - I used the same pea sized in the middle and didn't spread evenly beforehand either.
Oh well - I have two good coolers now.
Thanks all.
Good to hear. I always encourage a check/re-seat of the HS when there is abnormal temps. Sometimes the seating just goes wrong.Soooo yeah - you were all right.
Thanks all.
good score, doesnt tell us the temp though....I decided to put the 5600x into auto overclock mode +200 with the PA 120 SE, https://valid.x86.fr/bench/70myby/1
It just lets me have higher clocks then stock, what is still under the hood hiding, I couldn't do that with the stock cooler.good score, doesnt tell us the temp though....
So would you share your temps?It just lets me have higher clocks then stock, what is still under the hood hiding, I couldn't do that with the stock cooler.
Try keeping the ab icon in the task bar. I believe it keeps one temp reading with it by default.So far since adding more paste - this cooler has been great.
Idles in the mid to high 30s if my ac isn't on
Gaming it stays anywhere from 55 to 63
Cinebench roughly 68.
very happy so far.
Slightly off topic - but does anyone know how to keep afterburner core temps from moving on the taskbar? Every time I restart my comp, there's at least one that is moved around...
Should look like this -
But ends up looking like this -
