Did you have a hidden menu with other coolers? Amazing, because I didn't see any other coolers in this preview.
Oh no, you weren't actually comparing results from this preview to another one where the Tuniq was tested, were you?
Yes i am comparing with other review (Tuniq with same CPU @ 3.35)
I'll believe it when I see itYes i am comparing with other review (Tuniq with same CPU @ 3.35)
Scythe S-Flex fans use a Sony Fluid Dynamic Bearing (FDB), not ball bearings. There's a significant difference.Use the scythe s-flex fans, as they are the new fans for the enthusiast, due to high cooling and very low noise due to new kind of sony ball bearing.
check out anandtech.com in any of their cpu reviews for it....
also, is this thing better than ultra-120 xtreme????
f
The reviews I've seen show the Ultra 120 on top by 1-3C under heavy load. I don't call that a sharp beatdown, although I'd call it a win.I'll believe it when I see it
Considering the upgraded Ultra 120+ gave the Tuniq a sharp beat down, I have a strong feeling that the IFX-14 would hand the Tuniq its ass
..."Gameplay advantages: Use of a quieter fan keeps you from getting distracted by a dull whirring during a quiet scary FPS like DooM 3 or F.E.A.R..."
http://www.anandtech.com/casecooling/showdoc.aspx?i=2981&p=3The reviews I've seen show the Ultra 120 on top by 1-3C under heavy load. I don't call that a sharp beatdown, although I'd call it a win.
Note that at the time I posted my response, that review was not online yet. That review came out today, while my post was last evening.http://www.anandtech.com/casecooling/showdoc.aspx?i=2981&p=3
Under load at 3.9ghz, the ultra 120 beats the tuniq tower by 6 degrees, which is a 12% improvement. In the cooling world, a 12% improvement is a beat down.
This one wasNote that at the time I posted my response, that review was not online yet. That review came out today, while my post was last evening.
Are we going to see this tested with a 140mm fan? There's this Yate Loon to try. I'd like to see what performance/noise gains can be made by using a 140 instead of a 120mm fan.
I'm not even sure what you're saying, but the reason it's call Silent PC Review is because they are focused on silence. There is no reason for them to waste time testing loud fans. Just find out how many CFM your fan puts out and compare that to fans that are tested.<rant>The only problem with the various SPCR reviews is that they are so bull-headed about cut-off points for quietness that they leave out tests that would otherwise be useful for readers (ie. if I have fan X and I know what it's noise level is and I'm ok with that, it would be nice if it was included in the review - so *I* can determine whether some other fan works better, with less noise).
</rant>
yup. The one I posted happened to be an updated test using a retail version. I headed over to AT to find the original article (thanks Ender) and was surprised to see an update!
You're missing something. In the article AT wrote March 7, the Ultra beat the Tuniq by 6 degrees at 3.9ghz. That is a beat down.Yes, it was. And I rely on what I said earlier, having read that earlier review...the temperature differences weren't as dramatic in the first review. It was a win; just not a smackdown.
The newer unit with additional heatpipes and some modifications has increased performance over the old one, and is certainly more significant.
Although, it is disappointing that the new improved model doesn't come with Socket 939 mounting gear. And yes, I saw your reply to me about that review and sent one back over there.
Yep, I replied in an older thread about the big difference with the 120 Extreme and the other coolers in temps under load. At idle, the difference is negligible, but it doesn't matter. I'm 'extremely' curious what the FX-14 will accomplish in comparison to the 120 Extreme.You're missing something. In the article AT wrote March 7, the Ultra beat the Tuniq by 6 degrees at 3.9ghz. That is a beat down.
that's the $1000 question.I'm 'extremely' curious what the FX-14 will accomplish in comparison to the 120 Extreme.
That fan doesn't look very impressive to me.
62 CFM at 29 dBA
The Scythe SFF21F can do 70 CFM at 31 dBA
http://www.silentpcreview.com/article695-page5.html#sflex
62 CFM at 29 dBA
Where are these countless negative reviews?After reading countless negative reviews from the end users on the TRU120X as opposed to the godly review on AT, my only hope goes to the IFX-14. When will this cooler made retail? Does anyone know the ETA for it?
TIA
your loss, I guess.They're mostly regarding the mounting base isn't firm enough to support the weight of the heatsink and there's great chance that the heatsink isn't flat. Quite a few issues reported from current owners on various forums...
I was going to get the ultra120x but after reading all those, my hope goes for the IFX-14...hopefully thermalright will work on their quality control...it's a fact ....lots of cases
For Jet and Al, did you guys"lapped" your IHS by any chance?
Why would a slightly concave surface be of major concern? Didn't the reviews test the same product that's available on store shelves? If so, the excellent results obtained by the reviews should be attainable by consumers irrespective of apparent design 'flaws' providing one follows the installation instructions properly, and use the product along recommended operational environments/guidelines. I wouldn't fret about any perceived minor irregularities on the contact surface.Thanks for the replies guys.
If that's the case, it's somewhat a remedy to the common slightly concave HS base on the UltraX.
However, some ultraX owners would argue that it's the way TR designed the base to be slightly concave to get better contact with the IHS. A few people also reported that they get negative result from lapping the HS base and the real answer behind that could be various reasons from too much/little TIM or poor lapping job.
Negative. Spread AS5 evenly over the entire surface using a straight-edge razor. Wasn't concerned about flatness issues because I had read about TR's outstanding rep and the recent complaints had not yet surfaced at the time.
According to the AS5 instructions, a perfectly even HS base is not of paramount importance like we always thought it was. Bottom line is, all you relaly want is TIM between the HS and the heatspreader above the CPU core(s). So, if the concave HS base means 100% of the contact is directly above the CPU cores, I have no problem with that.Why would a slightly concave surface be of major concern? Didn't the reviews test the same product that's available on store shelves? If so, the excellent results obtained by the reviews should be attainable by consumers irrespective of apparent design 'flaws' providing one follows the installation instructions properly, and use the product along recommended operational environments/guidelines. I wouldn't fret about any perceived minor irregularities on the contact surface.
Who cares if AS5 covers the entire surface? All you really need is AS5 over the points where the CPU core makes contact with the heatspreaderI don't like the AS5 instructions and neither do several well known tech sites. They tell you to put a small amount in the center only and the pressure of the HS will somehow squeeze it out over the entire surface. I've tried it, and it doesn't work that way.
If your TIM is not spread evenly over the IHS, then technically, the latter is not flat, since the part with gob on it will be at a higher elevation than the part without. It's a small consideration, but a valid one. I prefer spreading a thin layer evenly over the entire surface of the heat spreader.
