More bling I guess. I was in that phase for a while, and I still like the RGB fans, but set to one static color and dimmed down for just the right amount of lighting.Seems kind of goofy to have one on an air cooler, but the masses love it.
I noticed that on Assassin X 120, Burst Assassin 120 and Assassin Spirit 120, but I couldn't find anything on their website about screen functions/features.Some of their single tower coolers have a little screen on it.
I am guessing you plug it into usb2 and use their software to run the screen.I noticed that on Assassin X 120, Burst Assassin 120 and Assassin Spirit 120, but I couldn't find anything on their website about screen functions/features.
They now have the Royal Knight 120SE, which is a competitor to the Scythe Fuma 3.
The main feature being that the heatpips are bent in an offset towards the rear panel. With a slim fan, it doesn't cover the RAM at all.
https://thermalright.com/product/royal-knight-120-se/
Its laid back like Le Grand Macho RT.Front tower is thinner also.. unlike PA120SE.. where both towers same width..
Sure.Front tower is thinner also.. unlike PA120SE.. where both towers same width..
In reality front tower fins don't need to be as big as rear tower because rear tower fins are using warmer airflow than front tower. Air is warmed up by heat absorbed from front tower.Front tower is thinner also.. unlike PA120SE.. where both towers same width..
if you have clearance over the vrm and ram you could alway mount them on the outsides, leave the middle empty.Hello guys,
I’m looking to buy a dual tower air cooler that can fit two of these Sanyo 140mm 38mm thick fans:
https://products.sanyodenki.com/en/sanace/dc/dc-fan/9RA1412P1G001/
I’ve been looking around for awhile, but it seems only an old Silverstone HE01 have that sort of fan clearance for the middle fan.
Would Thermalright have a dual tower that can fit the Sanyo 9RA 38mm thick fans?
Any guidance would be appreciated
That fan is a beast! Rated at 16.315mm H2O or 211.888cfm. That's right up freeagentt's alley.Hello guys,
