mista ting
- Apr 13, 2006
Ok so after browsing the AVS forums seems like everyone in there is filthy rich. Every one is recommending 300$+ fronts and saying it is the most important piece in a 5.1....but from the way i see it, it is a really inefficient buy and a waste of money. I have my receiver in which i can adjust the crossover frequencies. Anything above 80Hz the 5.0 channels take over.....frequencies under 80Hz the sub-woofer will take over. This leads to my conclusion what is the point in spending so much money on a larger front channel? which usually is just a bigger woofer than the rear........the bigger woofer and cabinet won't even matter because below 80 will get cut off and sent to the subwoofer..........wtf?
even the most expensive $1,500+ floor standing fronts can only go down to ~50hz.......but why pay more on fronts when you can just get a better sub to handle those frequencies?
