The way, way, way too early Pixel 4 thread
Discussion in 'Smart Phones and Devices' started by Commander Shepard, Jan 18, 2019.
  1. Commander Shepard
    Commander Shepard 2[H]4U
    3,208
    Apr 12, 2016
  2. ChronoReverse
    ChronoReverse Gawd
    1,004
    Feb 21, 2005
    They would have to license/steal Apple's chin-removal technique unless Google somehow invented a new way to do it. Even Apple's technique isn't perfect, supposedly if you look at how the glass curves, you'd be able to distinguish the part where the control electronics are hidden underneath.
  3. IdiotInCharge
    IdiotInCharge [H]ardness Supreme
    8,158
    Jun 13, 2003
    Put a headphone jack on the non-XL version and I'm golden...
  4. T4rd
    T4rd [H]ardForum Junkie
    15,934
    Apr 8, 2009
    Design can't be worse than the 3XL unless they somehow keep that huge notch. But I didn't see any benefit whatsoever to upgrade from my 2 XL, not that I would have anyways even if it was. That notch, 4GB RAM still, and with pretty much identical software and features (extra couple camera features are nothing to me too). The display on my 2 XL really doesn't seem much worse than my wife's Note 9, but I know that's probably hyperbole to the phone/display purists here. I did get lucky with the display lottery for sure though, as I know there was a wide variance across 2 XL's at least near launch.
    I've been pretty happy with my 2 XL though so far, but the Pie update was a considerable regression in UI and features to me. I really hope they being back WiFi/BT management in the notification shade, improve the gesture nav, maybe bring back vertical multitasking (highly doubt this) as an option, and eliminate the first notch even on phones without notches (so you can have more than a few notification icons).
    If they don't at least fix some of this, I'll definitely be looking at other phones when I need to upgrade in another year or so.
    exlink likes this.
  5. Commander Shepard
    3,208
    Apr 12, 2016
    Aside from the display, the 3XL ain't much different from the 2XL. My 2XL display was pretty bad, so I'm pleased with my 3XL. The notch doesn't bother me (much), but that notchless, chinless screen in the proposed 4XL pic sure looks nice.
    The only other 2019 phone that interests me is the OnePlus 7. I hope they improved the on-screen fingerprint reader. It only was about 50% accurate on the 6T I tried.
