Javelin3o4 said:Thats where i got mine when fry's got it..my cousin is the service dept. mgr.
Even with the Audigy2 cards the sound quality is better. Also, having a separate sound card puts less stress on your CPU, since onboard sound requires your CPU to do the decoding and such. At least thats what I've heard anyway.revlimit said:I've never heard the X-FI card in person, but can you really tell the difference between the Audigy or the on board? I was planning on using the onboard sound and connecting it to my receiver via the optical cable.
p0intblank said:If you like the case you have then you can get an external kit like the Koolance Exos-2. Thats what I'll be watercooling with.
p0intblank said:Even with the Audigy2 cards the sound quality is better. Also, having a separate sound card puts less stress on your CPU, since onboard sound requires your CPU to do the decoding and such. At least thats what I've heard anyway.
I haven't used a sound card myself but I use onboard on my current system and then went to a friends house with a sound card and it did sound cleaner and crisper. Not to mention the already stated less stress. I don't like the idea of unneccesary stress on my CPU. If I knew that when I built this pc I would've gotten a sound card.Gun_Strife said:yea thats what I hear about the less stress
but as far as actually using a sound card I never have b4, just used my onboard on my msi and its not bad sound quality and its what I'm used to
so point you have used onboard b4 and then added a sound card and heard a huge dif? cause I too was think about an X-FI line also thinkg preformance I believe
p0intblank said:I haven't used a sound card myself but I use onboard on my current system and then went to a friends house with a sound card and it did sound cleaner and crisper. Not to mention the already stated less stress. I don't like the idea of unneccesary stress on my CPU. If I knew that when I built this pc I would've gotten a sound card.
And about the Exos-2, I'm not getting the built-in one becuase I like the ability to choose what case to use it with, and being able to move it to another system later on if I wanted.
Everything is inside the unit. The radiator, DUAL pumps, and the resevior. All you do is route the tubes into the computer thru an empty pci slot. All thats in your case is the tubing and blocks.Gun_Strife said:very interesting about the card cause I've heard some peeps say its better but have never used onboard sound so I was woundering about that ty btw
and yes a very good point about the exos unit by itself but its so much, although I really do love the looks of the unit itslef, is th pump actually built into the unit that sits ontop
I'm pretty sure the biggest you can use is 3/8" because thats the size on the back of the unit with compression fittings, but you can use splitters and such within the loop to use smaller tubing if needed or desired.Gun_Strife said:yea thats pretty sick what size of tubing is able to be applied, is it stuck to only one size fitting or does it have options
p0intblank said:I have a question about hard drives. Would I be better off getting a Western Digital Raptor with this board or would a Hitachi Deskstar SATAII 3.0 GB/s 7200 RPM hard drive be faster? I would only be using one Raptor if I get one, and wouldnt be using any RAID setups. I'm not sure if this board even supports SATA150 does it?
Oh ok. Now then, would a single SATAII 7200 RPM hard drive be faster then a single SATA150 Raptor?mjz_5 said:sata II is backwards compatible with sata150
