It's going to be tough to do if you're using the board in SLI mode, since the NB is right the second graphics card. A Vantec fan barely fits under the second card.So what is this I hear that with the Premie you can't watercool the NB?
Dr_John said:It's going to be tough to do if you're using the board in SLI mode, since the NB is right the second graphics card. A Vantec fan barely fits under the second card.
Betauser said:i have this board and it seems that i cant run my 2x1gig ballistix tracer to 1T. it always crashes. anyone having this problem w/ X2 4400+ cpu? specs is right on my sig.
id like to know if updating the bios would make the difference.
Not sure...their layout looks essentially identical. But do you mean under a 7800 or other card? It's a pretty tight fit under my second 7800, and the water block does look a bit taller than the Vantec fan I have.Is there a difference between the Deluxe and Premium in this respect? I already have an Aqua Computer TwinPlex that fits just fine on my Deluxe board.
brom42 said:My specs are in my sig also. I am running my ram at 2-2-2-5 1T at stock speed and voltage 100% stable.
The OP mentions the major differences. If the Asus site is correct, the OP didn't mention the two boards have different Silicon Image controllers. Are the boards exactly the same size, hole position, etc.? Probably, but since I don't have a Deluxe to compare my Premium to, I can't be sure.TopNurse and Dr John... Read the OP and you'll see the differences.
Dr_John said:If the Asus site is correct, the OP didn't mention the two boards have different Silicon Image controllers.
forget the beta BIOS - stick with the latest final release 1005 works great for meWhite94Cobra said:I just finished building my new system (see below) and I must say, I'm disappointed. I spent three days trying to get WinXP installed to my RAID0 raptors on the NF4 SATA controller. I finally discovered that the DVD-Burner was causing my STOP errors when detecting the RAID array. Replaced that and Windows is now installed, but I can't get the board to go over 230 FSB.
Settings:
Memory: 200 MHz
HT Mult: 3
CPU Mult: tried 6-10
CPU volt: tried 1.3 - 1.475
Mem volt: 2.8
PCI: Locked to 33.3
The system just freezes shortly after booting at anything above 230 MHz. What's interesting is CPUZ still shows the multiplier as being 11 no matter what I set it to in the BIOS. What am I missing??
System:
Asus A8N-SLI Premium (tried latest beta BIOS)
OEM AMD X2 4400+
2x1Gig OCZ EL DDR PC-3200 Dual-Channel Platinum
XFX 7800GTX (stock 490/1300)
Antec TruePower II 550
Soundblaster Audigy 2
Antec P180
2x 74Gig Raptors
2x 250Gig WD
yeah somethings wrong somewhereWhite94Cobra said:Thanks... I'll try going back to the stock BIOS. I installed the beta in hopes of fixing my STOP error when installing WinXP. I just didn't go back after I resolved that issue. I would think even a lousy board would go above 230 since I have seen users hitting 300+
Settings:
Memory: 200 MHz
HT Mult: 3
Mem volt: 2.8
PCI: Locked to 33.3
System:
OEM AMD X2 4400+
Antec P180
2x 74Gig Raptors
2x 250Gig WD
EnderW said:forget the beta BIOS - stick with the latest final release 1005 works great for me
and BTW, huge update coming in a few days
well it's been delayedBoB-O TiVo said:What's in this update? Are you talking about the new BIOS? Any idea what changes it has? I noticed they updated the manual to indicate that you can use the second SLI slot for an x8 PCIe card in SLI mode now.
BoB
Originally Posted by Majin
I have seen some MOSFET cooling blocks designed specificly for the A8N-DLX. I don't see why you couldn't just place one of them on the A8N-PRM MOSFET/NF4 Cooler.
I saw them on a German WC site.
Viper87227 said:In order for that to work, you would have to have the heatpipe leading into the waterblock or you would have to cool the NB and Mosfets seperatly.
Opie said:I just built an upgrade with this board and Im really happy with it at stock speeds & stuff. However, the max vcore is 1.65, which is too low to OC my FX-53. Has anyone use the 1006 beta? Does it allow for more volts?
Ive also notice that the 1005 bios looks to be under-reporting voltages to asus probe. I have PC Power & Cooling 510 PSU in this and I *know* the volts are at or above all readings. Anyone using the beta checked this as well?
John Gault said:I have the same issue. I trust PC Power cooling.
brom42 said:I am running a Seasonic S12-600W PSU and I tested the Asus Probe against what I was getting with a multimeter taking readings off the lines. It was almost exactly the same, but the asus probe does seem to round/even out the voltages.
Have you tested your voltages with a multimeter in real time against the asus probe?
cischico said:This board sucks as far as vcore settings go with a dual core. You can only have 1.37 or 1.47 when changed from stock. For some of us 1.47 will be ok, but for the rest of us it's not. For some reason certain FSB's are unstable. I have GSkill PC4400LE and I know for damn sure that memory isn't holding me back at relaxed timings (2.5-4-4-8) especially when it is operating under it's spec'd rating. If anyone has a fix for any of the above please do let me know.
DBZ33 said:This is the first time I went with another motherboard. I always buy ASUS but I just returned my Premium A8N and went with a ABIT AN8 SLI Fatal1ty. I could not get more than 1.47 Vcore to overclock my 4400+ X2 and didn't want to wait for some kind of Bios update to fix it. Also with my water cooling setup the heat pipe was getting pretty hot with no fan one the heatsink. I wish the ASUS would of worked because I like there products alot.
titan97 said:I was trying to use my PCP&C 510 deluxe, but it died on me. I'm currently screwing around with a Antec TruePower 330W
-Dustin
zoinks said:is this just incorrect readings or is the vcore fluctuating? i plan to get this board with a 3000 venice(1.4v) so i believe i won't have issues, but this worries me.
