boardsportsrule
- Nov 27, 2003
ok, my pops and i have been working on making the "ultimate" htpc...this doesnt mean the FASTEST, but it means, the ast, easily workable, nicelayout etc. now, to do this we had to look around. first, you want a HDTV, not a standard one...we got one that has a vga monitor port in the back for old satalites. so we got a vga wire and plugged it into the computer. then you need a program to change the resolution and refresh rate appropriately, or this you'll want power strip. that will take you alotta time, and alotta messing around...when you choose a bad one, you will have to go to Svideo or reboot to undo it. once you get your hdtv hooked up, so it looks VERY clear(can read email on it with no difuculties..keep in mind this is a 27" tv too) you will need to get a program to organize/do everything...now eventually you should be able to buy microsofts program which should be great, but in the mean time we are using ShowShifter... its a british program, and abasolutely kicks ass! you can watch movies, watch tv shows, play music, view pictures, etc. all in one easy to use program that is designed for TV viewing!( HIGHLY RECOMENDED!!! can get a 15 day trial on their website!!)once you sort out all the bugs and get show shifter working right, you gotta move onto keyboard/mouse/remote problems....we had problems with people blocking IR keyboards, but RF keyboards were to expensive, or wouldnt shoot far enough...and the ATI remote was a POS! so we went looking....we found a IR keyboard with 3 ports it shoots from, so if one is blocked, no worries! we then used GIRDER to program the keys to pause, play, go ot TV go to music etc. in show shifter....then lastly, we bought a sony VL-700 mouse, had it "learn" the keyboards keys that were needed so that you could just use that! so now we have a hi res TV with one program for everything( exept surf the web
) and a keyboard(built in wheel mouse)/remote, and it will do anything we want!!! im happy : here are the specs for a pretty slow htpc
k7s5a
2200+ thorton(was a 1700+ pali before)www
512 ddr 2100 ram
160gb seagate with a 160gb maxtor as back up...
antecoverture case, stock fans and psu
zalman 7000a-cu
ATI 7500 AIW
sony 510 dvd burner
programs: girder, power strip,show shifter
TV/monitor: some kickass zeinith one
(this has lasted us 3 years with minimal upgrades(case, Vcard and cpu were upgraded, cpu was an RMA, and everythin else was CHEAP!))
now, from 1 foot away, you can hear a woosh of the fans...from 3 feet its DEAD SILENT with no outside noise, abasolutely wounderful!!!
just thought i should share how to make a good, cheap HTPC!
k7s5a
512 ddr 2100 ram
zalman 7000a-cu
ATI 7500 AIW
sony 510 dvd burner
