Wrench
- Sep 9, 2004
Will never go away in the States as long as there are muscle cars, and sports cars.
No the only time you actually use the clutch is for when you start off or come to a stop, the rest of the time you are shifting by RPM's or once you have been driving long enough you just go by the sound of the engine. Downshifting is where it gets tricky, you have to rev the engine to the appropriate RPM's and select the appropriate gear for the speed you are going.Wow, so you cycle through 1-4 with the selector in low, then cycle through the same positions again with the selector in high for 5-8?
That would be confusing as hell to me, but I guess you get used to it.
Do you have to double-clutch those things?
LoL what? Where the hell do you live that there's a restriction based on the cars transmission based on which car you got the license with? That's like putting a restriction on HP of what car you can drive because you took your test in a Honda Civic.I wouldn't give a license to anyone who can't drive a stick. But where I live, if you learn on an automatic, you're only allowed to drive an automatic with your license. So people are forced to learn them if they don't want that restriction on their license.
Maybe common knowledge in your circles. My (very) brief googling found nothing, I was hoping that since your familiar with the subject you might know where to find this info.The source is common knowledge, so I'm sure you can google some examples.
My argument basically is this, take two motors, one electric, one IC engine, both with the same peak power. If you gear them to both hit their peak power at the same speed, the electric will outaccelerate the IC engine, because it will have more power at low rpm. This makes going without a tranmission very reasonable with an electric motor, and extremely difficult with an IC engine without oversizing the IC engine like crazy.Electric motors have an efficiency curve, which you learn about with RC planes in particular when sizing them and the props. They absolutely have a peak power area that they are most efficient in. And regarding 0RPM torque, that prevents the need for a clutch/torque converter when coming to a stop, but not the need for a transmission.
Unlike an internal combustion engines, your legs produce about the same peak torque at 0RPM as they do at say 20RPM, and you don't have to worry if you stop moving them just like an electric motor. So why does your bicycle have a transmission? Because you can multiply the power of your legs at the sacrifice of speed.
There are also internal combustion engines that produce peak torque just above idle, and yet they too greatly benefit from transmissions. VW's 1.8 liter turbo produces peak torque at 1,700RPM, just 900 RPM above its idle speed. Yet it still makes sense not to shift into the next gear until about 5,500rpm. Why? Because of torque multiplication, where the multiplying factor of being in 1st gear is greater than the torque drop off as RPMs climb until about that RPM.
Also, a 7th generation Corvette can go from 0MPH to its top speed in 5th gear, as Jeremy Clarkson tested a few years back. So it too could operate without a gearbox just fine fixed in say 3rd or 4th gear, but it wouldn't work as well or be able to reach really high speeds. But, wait a second, why is it that most electric cars have such a low top speed?
Simple, again because they don't have a gearbox. So they put on the lowest gearing they can to reasonably hit a useful top speed without overspinning the motor, and just artificially cap it.
So an electric car with a gearbox would have:
1) Improved overall performance
2) Higher top speed
3) More torque at the wheels at low speed for towing
4) Potentially greater efficiency and thus range
Here's an article discussing how they are making electric specific transmissions, now that electric vehicles are becoming more popular, mostly 3-speed and 4-speed designs:
http://www.plugincars.com/efficiency-multi-speed-transmissions-electric-cars-107656.html
That is a load of shit but some people hold onto that myth just like the myth that screen tearing only happens above refresh rate...Driving in snow and on ice:
Worst combination:
Rear wheel drive and automatic transmission
Best combination:
Front/all wheel drive and manual transmission
That said, I live in an area that doesn't get major weather issues (i.e. snow, sleet, ice, etc) and freeways are very clogged, in a city that's quite hilly (yes I actually go up hill both ways to work!), as a result automatic is the way to go. Manual transmission is a dinosaur, but then again this thread shows you have pompous fucks who think that "it's not really driving" if you're not driving a stick.
I'm at a total loss as regards what comes next. I used to be a car enthusiast. Now, since I have become disillusioned and don't like anything on the market (within my budget) cars have just become grocery getters to me, and that makes me a bit sad.
The knowledge comes from electric conversions, in which they found the instant torque of electric motors would break traditional ICE trannies, even when the motors were of lower peak power.Maybe common knowledge in your circles. My (very) brief googling found nothing, I was hoping that since your familiar with the subject you might know where to find this info.
You're confused. You think that full potential torque at 0RPM with a flat torque curve means MORE torque than an ICE engine below peak horsepower, and that's obviously false. Flat != More. My mom's 2.0 liter TDI produces only 140 peak horsepower, but it produces 240ftlbs of torque just off idle. The TDI produces far more peak torque than a 140 peak horsepower electric motor, at the crank even before you factor in torque multiplication from a gearbox. The TDI requires a transmission because you wouldn't be able to stop the car without one, whereas the electric motor does not. Both will benefit from torque multiplication with a transmission.My argument basically is this, take two motors, one electric, one IC engine, both with the same peak power. If you gear them to both hit their peak power at the same speed, the electric will outaccelerate the IC engine, because it will have more power at low rpm. This makes going without a tranmission very reasonable with an electric motor, and extremely difficult with an IC engine without oversizing the IC engine like crazy.
You're confused again. Those twin motor designs do "switch gears" when engaging the second electric motor, same as Chevy does. Its some kind of weird helical gearbox design.Even racing teams in formula E do not agree whether transmissions on their vehicles are beneficial or not.
http://www.fiaformulae.com/en/news/2015/november/boxing-clever.aspx
http://www.fiaformulae.com/en/news/2016/october/insight-how-the-cars-have-changed/
Well, in theory, no traditional manual or automatic transmission should be able to compete with a CVT. Because CVTs hold the engine at peak horsepower and never have to shift, they should always, without exception, be faster than switching gears.CVT's are not used because they are good, or because they offer features above Auto's or Manuals.
My dads 59 is a granny first, second, and third. No difference between starting in first or third gear except when you have to shift next.I do not necessarily apply this to Pickup Trucks though. IMHO, you cannot beat a heavy-duty Granny-First 4 speed Manual in a 4 X 4 Pickup.
Thats what I grew up with, and I still think it provides the best balance.
I mostly drive manuals, and I'm certain I get worse mileage with them just because I'm usually in a lower gear than necessary and having fun. Automatics are like zombie boring time.I can drive both. New car is automatic, my old car is manual. So far, I think the old manual gets better MPG in the city, but the new one does a bit better on the highway. I honestly don't care which I drive, but as we move to hybrid/electric tech, I think it's likely that Automatic will be more efficient. I'll also add that I know a lot of people who can't drive a standard. I'm not sure I know anyone under 40 that can drive a standard and I know plenty of older individuals that can't and are scared to try (even though I think the days of standards being hard to drive probably ended in the 60s or 70s.
I had a 65 ford 3/4 ton pickup like that. You could idle up a cliff in third in that thing. Oh and you never started in first unless you like redlining at 7 mph or so.My dads 59 is a granny first, second, and third. No difference between starting in first or third gear except when you have to shift next.
It's all in the tires. I dare you to try driving my old integra gsr up any incline in even the lightest snow when I had summer tires.Driving in snow and on ice:
Worst combination:
Best combination:
Problem is I heard its been for all intents and purposes impossible to make a CVT that can handle a lot of horsepower without slipping, and from a marketing standpoint people really hated having their engines hanging indefinitely at peak horsepower RPMs all the time as instead of a cool vrooooooOOOm... vrooooOOOOm, you get DROOOOOOOOOOOOOOAN which sounds crappy.
Only in the hands of an expert driver. Sadly, 99% of people who like to think that they are expert drivers, aren't.To mention as well, auto draws more fuel from the engine than a manual. I like manuals over auto. They're fun, save fuel, n if its a suped up vehicle, they are faster.
As proven on the track.Well, a modern-day, well-designed flippy-paddle gearbox simply works better and shifts faster than any human could.
Depends on who you talk to. Brother in law is an auto trans mechanic. Says once you know the technology, they're pretty simple, and the heavy duty ones can handle as much power as you want. The big factor is wear is heat; he says almost every transmission cooler is inadequate for the car it's in; that they would last forever if properly maintained and cooled. He's installed a larger cooler in every car the family has owned, no transmission problems. Even the new autos that are known to fail, there have been fixes developed. But the big manufacturers won't recall them, because it's cheaper to fix whatever fails during warranty, and have the customer pay when they fail beyond that, or just sell them another car. But the E4OD Fords, Big turbohydramatics from GM, and Torqueflights from Chrysler, basically all the heavy duty trans used on the high hp/torque engines, were very reliable.I've been driving a stick for decades, one thing to factor is manuals are more durable, easier to fix and maintenance is cheaper and the intervals are longer.
By the end of the next decade, my beloved manual transmission may no longer be an option.
Manual transmission advantages:
1) Improved fuel economy
2) Improved efficiency so more horsepower (less parasitic losses)
3) Lighter weight
4) Simpler and thus cheaper to make
5) Clutch slip provides enhanced control at low speeds
6) Being able to anticipate gear selection (I can shift before I'm about to pass, instead of starting to pass and waiting for the automatic to realize I want it to downshift)
7) Greater control through engine braking
8) Greater control by "hanging" on to gears when appropriate
9) Its fun!
Downsides:
1) You have to have additional driving skill to know hot to operate a clutch, and if really mentally challenged may find it a distraction and get into an accident (if rubbing your belly in a circular motion while tapping your head causes so much confusion you lose bowel control, stick is not for you)
2) Can't as easily eat french fries and talk on your cellphone while driving (stop that, fatty)
3) The best automatics actually shift faster than most people can manually now
4) With very powerful engines, clutch weight can sometimes be high and cause leg fatigue in small girls and males with the muscle strength of small girls.
