nice pic, wanna do a couple more?also, what did you mod in that case?
[MG]http://img819.imageshack.us/img819/377/noctua.jpg[MG]
At first I was looking for the power supply, but is that what the black PCB is above the motherboard?
does that ion board get too hot? i am thinking of upgrading from ym zotac one which has a fan
http://img193.imageshack.us/img193/8462/p1020028fo.jpg
http://img192.imageshack.us/img192/8534/p1020025c.jpg
http://img6.imageshack.us/img6/3713/p1020023s.jpg
http://img810.imageshack.us/img810/5972/p1020020f.jpg
http://img810.imageshack.us/img810/5527/p1020019.jpg
http://img89.imageshack.us/img89/8186/p1020016.jpg
http://img340.imageshack.us/img340/7359/p1020014u.jpg
http://img440.imageshack.us/img440/4192/p1020013w.jpg
http://img522.imageshack.us/img522/9715/p1020012c.jpg
thats a lot of lights! what gpu heat sink are you using? also, is that case pretty loud with all those fans or are they on super low speed?
The heatsink is the NH-D14, just swapped out the fans. The Apollish fans are actually pretty quiet, <20db. I have 7v resistors on the zotac fans on my heatsink, and the 200mm megaflows are pretty quiet <17db as well.
hm never heard of apollish. sounds fairly quiet then. and i was asking about the gpu heat sink, as it definitely doesnt look stock.is it the gelid icy vision one?
New System Specs
I7 980x
12GB Corsair Dominator GT 1866 (My change to Super Talent 2133 cl8)
Asus Rampage III Extreme
3x Evga GTX580's
3x Intel X25m g2 160's raid 0
laptron fc2
Creative Fatality
Cpu, MB and GPU's EK blocks
3x GTX 480'd 3x GTX 360's
18 Noiseblocker HS fans
Dual MCP655
Ek Serial Sli setup
BP Tops and covers
Frozen Q Res
here is my old Lian Li midtower that I modified to fit a 120x2 and a 120x1 rads. it is also my first time water cooling. please critique
Specs in sig
/IMG_5656.JPG[/IMG]
A commissioned oak and aluminum case.
- Form factor: HPTX (EVGA's SR-2)
- Dimensions: 46 x 27 x 35 inches (HxWxD)
- Weight: 161 pounds
- Materials: Solid red oak and oak veneer plywood, .10-inch aluminum sheet, .125-inch angle, all stainless steel fasteners
- Finish: black wood stain with wipe-on polyurethane, black powder coating
- Internal drive bays: 37 x 5.25-inch
- PSUs: 2x
- Two custom radiator mounting brackets to hold 4 x 140x4 radiators
- 140mm case fans
Phenomenal. So what is going in this thing?
