I have both ATM. I bought the w2007 at walmart and the w2207 at circuit city. I was more impressed with the out of the box performance of the w2007. I'm on the 2207 now and I'm thinking I may take it back. But I need to be more fair and at least try to calibrate it more. Neither are calibrated. The factory "quick settings" on the 2007 seem to be more effective than the 2207. The 2207 seems a bit washed out at the moment. The 2007 as a .256 dot bitch whereas the 2207 has a .28 That may be noticeable in DVD and games, not sure yet. I doubt it. The 2207 and 2007 are both excellent displays...but I was more impressed with the performance for the 2007. The 2207 is almost too much, which I hadn't thought it would be and I decided to take it back I'm going to have to fight circuit city. There is NO WAY I'm allowing them to just take 55 bucks of MY money for no reason other than "they can." Retailers have no business charging restocking fees. Etailers, fine
anyways...I'd like to see the color profiles of "calibrated" m2007 and 2207 monitors but nobody is sharing or has calibrated yet.
which panel is Better???
So How Are You Guys Calibrating Your Monitors? I have both the 2007 & the 2207. Both are fantastic. Had them just over a week & love em both. Mac on 1 & Vista/XP on the other.
So what are your settings, Colour, Brightness, Quick View etc & how did you calibrate them?
Cheers
Too bad so much useful information was lost on this thread during the server crash, and subsequent backup. I don't think most know just how many panels have been used in the HP w2207's short history. And I'm still not entirely sure how to accurately differentiate between some of these panels: Innolux, Samsung, Philips. Again, seems as if some of us are almost talking about different monitors entirely.
What chew talkin' 'bout Willis?
I'll post the calibration settings once I get my spyder2 next week. Which do you think has the better image quality?
I just have to say, I'm completely impressed with this w2207, so much so I had to join and post my thoughts.
Greetings. I finally got around to calibrating the w2207 with spyder2express and it looks MUCH better in games, movies and pictures. I had to tone down the brightness/contrast a bit for web browsing but left everything else the same. No more saturation and colors do not mix.
Here is the download link: http://user.pa.net/~starner/dir/Spyder2express.icm (right click, save as)
Be sure you have adobe gamma turned off and any other graphics apps that may be running in the background that would alter the color settings. Use the windows color management to load the profile. Not sure how it will work for the rest of you without going thru the actual calibration process but I would say it was $60 well spent. Before I was on the fence about the w2207 since I had already seen how much better the w2007 was out of the box...not anymore
Can you tell me what are the brightness & contrast values that you used? Also what color patter are you using with that configuration?
One last question: What video card do you have installed, Ati or nVidia card?
Tks
On a separate note, I am having issues with my mouse pointer slightly disappearing from the bottom and right of the screen. It goes completely off the edge of the viewable screen just barely. I am using the DVI connection. I am wondering if anyone else has encountered this issue and how you resolved it. Thanks!!!
Hey guys I picked up this monitor 2 days ago after reading all the rave reviews from this thread. I'm coming from a Sony 21" Trinitron CRT and this is my first LCD.
There's no dead pixels or any noticeable ghosting.
My panel number is LM220EW01-V2, this is an LG right?
Anyway I was wondering if this normal for LCD or just TN panels. I'm sitting directly in front of the monitor and if i slouch or tilt my head down a bit the colors of the top portion of the monitor gets darker.
I'm also having trouble getting the colors right, I'm currently using Text mode and turning down the brightness and it looks decent on the desktop. Games like WoW looks great however.
I guess if the angle issue is a TN thing I'd probably get the NEC 20".
No, this is an Innolux screen. You're the second to have one on this thread besides me.
I can't read the specs on that website, but I can say that when I bought mine here in Beijing there were both an HDMI version (2207h) and a non-HDMI version (2207). I doubt if there are any significant differences between the two models, just the input difference.
The same is true for the 2408 model which the store had on display as well, both h and non-h models were available.
I just received a 2707 (from Dell in the US) where the panel looks like it wasn't installed square inside of the brushed alum frame.
This photoshopped image will give you an idea of what I'm talking about. Notice how the right top corner of the blue screen is lower than the left top corner):
If you are a 2707 owner would you please check your screen and let us know if the panel is installed square or a bit skewed.
Thanks!
PS - a similar issue as mentioned in this older thread:
http://www.dellcommunity.com/suppor...dim_monitor&message.id=83532&jump=true#M83532
just a stupid questionI haven't had a lot of chance to play with the different resolutions but it does not look like this monitor supports 1:1 pixel mapping. It will stretch the image to fit the screen.
