cornelious0_0
- Apr 6, 2003
You lucky bugger...me wants colder cpu.
clocks are correct 500mhz core with 50+ delta so 551/1386 but how to confirm clocks as AM3 says 552/1386... ? only can show you my PCmark05 as well as 8,383 http://service.futuremark.com/compare?pcm05=309796 although at 556/1386cornelious0_0 said:eva...I got all your scores/results posted up on the front page...but can you confirm the VGA clocks for that AM3 run...as they're quite low compared to UniB's score that's less than 1000 points lower than yours...and he's running dual 7900GTX's at 690MHz. Not calling you a liar...just seems weird that with only a 100MHz CPU advantage you'd be beating him by that much with near stock clocks on your 7800GTX's.
I'll leave it as is because I do trust you, but if you could clear it up for me or get a newer result posted that'd be great.
Air Cooled 420 said:Curious, where do you find a DIce Tube? are they cutom made..
Its CF corn.cornelious0_0 said:Yeah man, less than 30 seconds sure would be slick.
Nice scores...I'll be doing updates this afternoon gauranteed.
Updated in process...just wanted to clarify, the latest AM3 result (cent) is still with a single X1900 right?
NEVER!cornelious0_0 said:forgive me?
