Dj_ said:Heres mine on my P4 4.15ghz, going for 4.25ghz later, wish me luck
jamezzz122 said:Nice processor there buddy...And you have a half-naked guy for your wallpaper
cornelious0_0 said:Weird, I never noticed it before....and now you've got me wondering.
Maybe you could go straight to the source and email AMD about it, and see what is exactly effected in/by the different Brand ID's.
uclajd said:cornelious,
Maybe you could extend the lists to top-20 or top-25? It would encourage more participation, IMO.
BTW, I am getting my modded board back on Thursday, so expect a faster run.
Frank Castle said:Here is mine,I believe this is correct for what I should do.I hope this puts me in the top ten!I will be getting faster memory shortly,right now all i can run my mushkin at is 245 1\1 at 2.5-4-4-6
mike.elmes said:Hi guys. I just finnished a record time of 23min 01 seconds but can't seem to find a way to post a screenshot. How??
Never mind, I didn't read the first page.
Luciferin said:guerillah, havent really tested it much at 2.77, just tried it for the superpi run, day to day have been using it at 2.75. At 2.75 it has been stable in prime for long periods of time at least a few hours, and has also been stable in vampire bloodlines. Usually load on it has been around 52-54C when priming but there are a few things i want to do this weekend to see if i can bring the temps down a bit, for some reason small foamy air bubbles (happened when i added a bit of water wetter) will not come out of the loop so im gonna drain and see if i can get rid of them, hopefully improve temps some. The bubbles are driving my temps up, it used to idle in the 30's and after the water wetter/foam it has been idling in the 40's. How about you, what are your temps looking like? also whats your max clock and what week was your proc if you know it?
James Earl Ray said:Dude you rock. Lets see some 3D benches!
Guerillah said:At 2.71 ghz at 1.5V, I idle at about 33C, and load at 42C in prime95. The computer is stable in everything at this setting. This is 1 loop with cpu and 6800GT in it. I have water wetter and distilled water and luckily have not experienced the same problem you have. Are you using any kind of a divider to get your FSB that high?
centvalny said:I'm thinkin jump to red ship. Green one kinda out of gas
I'll have to admit, I was hoping to get a bit more OC out of this. Don't guess I should complain, though...the FX-55 is fast as damnit from the factory.
Prolly so Its kinda lonely being green at ARC and ORB nowadayscornelious0_0 said:Let me know when/if you do decide to make the switch...and I'll hold my breath that you get an XT-PE that overclock as nice as mine, as I've got nothing but good things to say about my card hitting 650MHz /w 1.62v and nothing but the pencil mod done to the card.....and my load temps are still a tad high, so I'm pretty sure that with h2O and 1.75v or so should get me to my goal of 675MHz.
It's such a fun ride on the red rollercoaster right now, won't you join us?
centvalny said:Prolly so Its kinda lonely being green at ARC and ORB nowadays
