n64man120 said:j/w wuts doubled caps and mosfets?
With all due respect, none are really equipped for it due to power, heat, and droop issues, and the Max3 is one of the worst:cornelious0_0 said:Not ALL s478 boards can handle OC'd Presy setups....but many still can, and the MAX3 is one of them so far...all it really needs is the VTT and vdimm mods to be good to go for extreme OCing.)
uclajd said:With all due respect, none are really equipped for it due to power, heat, and droop issues, and the Max3 is one of the worst:
(MAX3) is the weakest of all of them. It only supplies 75 Amps continuous, where the IC7-G supplies 105 Amps continuously. This is only due to the fact that Abit fitted one powerfet per phase on the MAX3, and two per phase on the IC7-G. Probably they did this just to accomodate all the extra gizmos of the MAX3. SourceFor the seminal thread on this issue, (and the supreme experts on this issue) see here, just so we don't hijack this one.
But I will say, when I get the modded board, if I run 1.7v through this puppy with no droop, I'm going for 24 minutes.
yes.. perfect.. now lets educate the idiots that dont realise that someone can modify results tthe other waysabrewolf732 said:Is that all I need
ryuji said:yes.. perfect.. now lets educate the idiots that dont realise that someone can modify results tthe other way
Guerillah said:31 minutes, 16 seconds, EDIT: ah crap, I didnt see that you wont be taking them like this now Guess I gotta rerun the damn thing over again.
karnick said:i also barely fit the screen lol
snakebiteuk35 said:
Alex41290 said:dude...you have an FX-55...AT STOCK
....OC the living crap outta that thing...get watercooling or a Prommy, jeez...when you have a "higher being" like that, you hafta take advantage of that..
good luck! and nice time!
