cornelious0_0
- Apr 6, 2003
James Earl Ray said:I just scored the exact same score after the patch. 6949. And that was with the cpu 30mhz slower. Go figure.
I see.......interesting.
Hey you got a picture of your rig? Would like to see it...James Earl Ray said:
Grahxen said:3D Mark 03 13,820
I took apart my BFG 6800 ultra, lapped all the heatsinks and applied artic silver 5 to everything, i was able to sqeeze some more MHZ out of it, as well as lowering temps.
http://service.futuremark.com/servl...ojectdetails&projectType=10&projectId=3201829
Grahxen said:
Grahxen said:
genen said:Photos - you got photos of the procedure?
boostieboy said:WTF, why am I the only one with the 6800 in the top ten, where are all the Ultra people?
cornelious0_0 said:aoc007, your score is actually abnormally low.....my P4 was clocked at 264fsb for 3.69GHz, with my memory at 1:1 2.5-4-4-7, and my GT only clocked at 440/1200 and you're less then 100 points ahead of me. Give me a 3.9GHz P4 and a 6800 @ 475 core and I'd be clearing 6k easily.
What drivers are you using for that 5800 score?
btf said:13517
http://service.futuremark.com/compare?2k3=3217122
This is without tweaking. I should be able to get more.
Ultra was at 450/1290
cornelious0_0 said:Good stuff bro, ya just made it.
btf said:Not many ultra's up there
After I flashed my card with the extreme bios I was only tring to push the core and ram. But it has artificats so I stopped. Then yesterday I started upping the ram only. It's completely stable up to 1290 no artifacts.
Doom3 timedemo is really impressive:
1280x1024 high detail 8xAF = 92fps
1600x1200 high detail 8xAF = 84fps
rtierney said:Hopefully someone here can lend me a hand.
I'm having an odd error installing 3dMark05.
After I go through the first few screens, I come to the "what directory would you like to install in" screen (or a similar name), and it defaults to the Windows directory and the install size is 0MB.
That obviously isn't right.
When I hit next, it instantly goes to the finished screen.
When I uninstall, it zips through the uninstall, literally finishing in under a second.
I've tried deleting all associated 3dmark05 registry entries manually, but still no luck.
Has anyone else run into a problem like this or know how to fix it? Nothing like this is posted on futuremark.com, unfortunately.
btf said:Sounds like the file you have is corrupted, have you tried downloading it again?
rtierney said:yep, twice.
this all happened when i installed the patch for the latest version of 3dmark05.
as soon as the update finished, the program never worked again and it's been that way since.
Because you guys are "optimized" for AquaMark and 3D Mark 2003.Futuremark's got to pass it around to the different GPU mfgs ya know.boostieboy said:WTF, why am I the only one with the 6800 in the top ten, where are all the Ultra people?
haroldmeyer said:Because you guys are "optimized" for AquaMark and 3D Mark 2003.Futuremark's got to pass it around to the different GPU mfgs ya know.
cornelious0_0 said:Were you using a cracked or non-legit serial by change? I've heard of the patch having direct effects in relation to the ability to use nonlegit serial numbers.....just a thought.
Oh, and Gundamit.....'grats on the new score.
Update tomorrow after I OC my processor, I'll also hit #10 I think in 3D03. Big epenises are fun
any idea on how to reverse whatever applying the patch did so i can go back to normal 3dmark05? or atleast get it to install at all?
IceWeasel said:anyone still pay attention to this thread??
cornelious0_0 said:It's alright though, I'll take Aquamark3 over 3DMark anyday...still my favorite benchy.
Alex41290 said:I'll have to agree with you on that...
and to the post above...holy chit....660 on the core :O!!! that is freakin crazy! next thing ya know we'll be running 1GHz on the core...te hehehe
mentok1982 said:I agree with you on all counts. Some of these guys had proof and some did not. I will see if I can get them to post here.
