will my GTX980 SLI be able to maxout The Witcher 3 at 1200p?
this is the big question.
I hope that it will support SLI at least since CD Project are famous to not support SLI at game launch.
Hi all,
I have system freeze during playing games.
The CPU/RAM seems stable under every synthetics, I tried running the system at stock frequency but the system still freeze after some hours of gaming.
The only components that I don't set to stock frequency are my two EVGA GTX980 SuperClocked (I don't added any overclock to the one made by EVGA), do you think that a system freeze may be related to the overclocked cards?
Yes.
Easiest way to tell if its driver related or clock speed/heat/power related is to slow the cards down and see if the crashes lessen/stop or if they continue.
They could be the cause or triggering another reason for the problem, like too much system heat or PSU is on its limit.
Do the test first to see which direction to progress.
For example, I get an occasional crash in TW3 with my 980ti (like once an hour).
I started reducing clocks but they didnt stop.
So now I put the clocks back up and just have an occasional crash, one of those things for now.
Overclocking and running SLI are a known problem combination.
Just overclocking should have stability verified but you appear to not have a care for this.
I mentioned some possible reasons why the freeze can occur, have you done any further investigation?
There is no mention of what you have done to ensure they are functioning properly.
Its up to you to troubleshoot and if you have, tell us what you have tried.
You should not be considering returning them until you know they are faulty.
No I dont agree, I already explained why.
I asked what you had done "further".
You then asked why they could be the cause of the problem which I had already stated in my first post.
I said that so you would be clear that the cards can cause other problems without being faulty which you ignored.
I have to wonder if its worth saying anything more.
You said you overclocked one of the cards.
You didnt mention the stock speed, the overclock speed or the max temp it reaches.
You havent stated how you made sure it was stable.
What are the max idle and load temps of the GPUs?
What is the max idle and load temp of the CPU?
Ah, thats not what you said in your first post, it was a bit confusing.I don't overclocked any cards, I have two EVGA GTX980 SC that are factory overclocked and I was using them with the factory overclock.
CPU temp looks ok, GPU temp is too high.Temperature are ok on both CPU and GPUs.
My CPU does not go over 65°c, it idle at 40°c because of my fan policy,
my GPUs does not go over 82°c on the hottest one and they idle at 32°c and 36°c with the fan spinning at around 1100RPM.
I have two EVGA GTX980 SC that in factory are clocked at
1241MHz Base Clock
1342MHz Boost Clock
I donwclocked the cards at
1126MHz Base Clock
1216MHz Boost Clock
and I have no freeze after the downlclock.
with the clocked cards I can't play more than one hour without a freeze, with downclocked cards I can play for hours without any freeze.
what else can be if not the factory overclock of the cards?
You hinted that the gfx cards are overclocked.
The stock speed is the speed they come as.
The standard 980 card speed is called reference clock speed.
I suspect your case cooling isnt good enough for SLI and/or you havent increased the fan speed.
The cards are in SLI so will get hotter, this requires decent case air flow and maybe a fan blowing directly on them.
You may also need to increase the fan speeds under load.
82°c are not too hot since 80c is the desired temperature.
in any case I cannot understand why I should act on fans, does the firmware is so stupid to get the cards hot and don't higher the fan rpm?
yes, it is so stupid. this is the last factory overclocked card I buy, I tought something better from EVGA.
I see on the web that there are a lot of people who get this problem with GTX980 SC,
is there a way to RMA my two factory bugged cards for working cards like GTX980 Ti?
