Casej18 said:Well i bought the powercolor version and the best that i can find on the box is "HDTV ready" Does that mean the same thing?
Bona Fide said:This thread needs a STICKY on the double!
Terra said:Why?
Is there a sudden stream of HDCP movies that I'm not aware of?
Terra...
hken said:Is HIS iceq3 x1900xt HDCP ready?
The review from hothardware.com says it is.
Review from hothardware
What would be good is if MSI made an HDCP-enabled derivative of the NX7900GT-VT2D256EZ.mentok1982 said:What a huge day for HDCP!
I found two more 7900 GTXs, I have listed all the 7950 GTs that I have found and I have listed
all the 7900 GSs that are HDCP ready so far.
gvlada said:Will anybody explain to me if I have a no-HDCP vga in Vista system and try to watch any hi-res movie throu dvi what will happen? Will I see something and in what res? Then HDCP is content protection not copy protection....hmm....example you have Blu-Ray or HD-DVD writter in your rig. You need HDCP card and monitor for watching but you can easilly copy entire movie with something like dvd x-copy platinum from 321studios (meaning something similar to x-copy but for Blu-Ray or HD-DVD) to your HDD and write it to a blanc disc. What kind of a protection is that? Explaine me, please. Thanks in advance.
Devnull said:Any idea if the X1950 Pro cards will be HDCP ready? I wouldn't mind having HDCP support when I upgrade, but I don't know what I will be able to affoard.
RangerXML said:Sorry to "dood doo" on everyone one fun and this list, but we are mere months away from DX10 which will more then likely start this whole mess over again with new video cards. Not to mention you also need an HDCP ready monitor, not just a video card. Not to mention we won't see a steady flow of Blu-Ray or HD-DVD Roms till propably next year around mid to end summer.
In order to watch an HDCP movie you'll need 3 things (figureatively): HDCP media (either d/l video, DVD, Blu-Ray or HD-DVD), an HDCP video card and an HDCP ready monitor. Not including proper codecs and filters. This is gonna be a major pain just like when DVD first came to the scene.
compwarez said:where do i buy this card "Gigabyte 7600 GS GV-NX76G256HI-RH (HDMI)"
Just listed (but no pics): NX7950GT-VT2D512EZ. Passively cooled, so should be directly in competition with the <--->MSI</---> XFX card.Ajax9000 said:What would be good is if MSI made an HDCP-enabled derivative of the NX7900GT-VT2D256EZ.
Passive cooling (or a large+slow fan) is what I'm after for my HTPC project. A "NX7900GT-VT2D256EZ HD" or a "NX7900GS-VT2D256EZ HD" would be very nice.
Frosteh said:I have some questions about HDCP support, any answers would be appreciated
I have a 7950GX2 and an Iyama CRT 19" monitor that can support upto 2048 1536 resolution
1) What is the resolution of HD movies running at max quality?
2) My monitor has a standard analogue connector and my video card has dual DVI output on which I attach a dongle to change the connector type, can HD be played out through a DVI output (using a DVI to analogue converer dongle) and still display on an analogue monitor?
3) Does the 7950GX2 support HDCP decoding? If not is it possible that driver updates in future could add this functionality or does it need a bit of hardware that cannot be emulated with a video card (even a very fast one)
If you want to watch new HD DVD or Blu-ray movies on your computer, you will need a HD DVD or Blu-ray drive to start with. Then you will need NVIDIAs ForceWare v92.91 Beta driver assuming you are using an NVIDIA video card, and player like CyberLinks PowerDVD 6.5 HD that supports HD movies. If you are using an analog connection to connect an analog or digital display, you dont need more hardware or anything special till Hollywood starts putting the ICT on their HD movies, rumored to happen in 2010.
If you are outputting your HD DVD or Blu-ray movie to a digital display, with a digital connection, things get a bit more difficult and you will need a couple more pieces of hardware in addition to what is talked about above. To keep a purely digital signal from one end to the other, you will first need a video card that has HDCP support provided by an included cryptorom chip on the video card itself. Then the digital connection between the video card and the digital display must either be DVI or HDMI. Then the digital display must have the cryptorom chip as well that makes it HDCP compliant also.
Frosteh said:So I dont actually need a HDCP supported video card OR monitor, to get HDCP output, as long as it uses an analogue connector?
Will the analogue connector provide a worse IQ?
Will the analogue connector force the HD DVD to play at lower resolution?
mentok1982 said:Not until the ICT is implemented and at that time you will also need a HDCP display
connected with DVI or HDMI.
I don't think so. Not unless you can see a difference between 1920x1080 delivered via an
analog cable and 1920x1080 delivered by a digital cable. You might want to ask the folks
in our Display section about this one.
Not until the ICT is implemented on HD media.
