Zarathustra[H]
Extremely [H]
- Oct 29, 2000
Pains me he used Corsair fans on it. I would of just used 200mm noctua's...Or Arctic fans if I wanted a good blend of noise/performance. But I'm biased towards them. Love my Mo-ra3 with the 200mm noctua choice. Can barely hear the thing running, and my water temps are always just barely above ambient. It's great.
I have a Noctua 200mm fan as a case fan in my backup workstation / testbench build (built into an OG Phanteks Enthoo Pro case)
If I am going to be honest, I have to admit I have been pretty underwhelmed by it.
At higher speeds it has an audible hum (not just a white noise whoosh). To get it to behave and not be annoying in that case I had to use the included Noctua speed reducing adapter (essential a resistor in a short fan extension cable). This was in part due to the fact that I have an old Supermicro server board in that case, and server motherboards generally don't have the best fan speed control for desktop/workstation use.
That fan just doesn't seem to produce a good airflow to noise ratio IMHO, and static pressure is utter garbage.
For this reason I had originally planned on going with the 140mm fans like Der8auer did above. I always like to push/pull everything with strong high static pressure fans, but after talking to the Watercool folks they essentially told me it was optimized for low static pressure fans like the 200mm Noctua, so I wouldn't gain much by using 140mm fans, and would probably just make cable routing a nightmare, as the 140mm fan bracket doesn't have the built in cable routing that the 200mm fan bracket does.
So I took their advice and ordered the 200mm bracket.
With two of the MORA IV 600 bad boys, my cooling capacity is going to be so overkill anyway, that it probably won't matter, and they are going to sit in another room from my office, so I probably won't hear the hum, if there is any. (it's possibly my one previous 200mm Noctua fan was defective or something)
All of that said, I used to be a huge fan of Noctua fans. I went with their Industrial PPC line of fans for my current build 5 years ago:
22 of them in fact. 16x 120mm fans on the front two 480 rads and 6x 140mm fans on the top 420mm rad, but I had nothing but issues with them.
Noctua - at some point - altered the circuits on their fans such that if you use PWM splitters to run multiple fans per channel the speeds don't work right, resulting in a behavior something like this:
0% PWM -> 0% Fan Speed
10% PWM -> 0% Fan Speed
20% PWM -> 0% Fan Speed
30% PWM -> 0% Fan Speed
40% PWM -> 0% Fan Speed
50% PWM -> 0% Fan Speed
60% PWM -> 0% Fan Speed
70% PWM -> 0% Fan Speed
80% PWM -> 0% Fan Speed
85% PWM -> 20% Fan Speed
90% PWM -> 50% Fan Speed
95% PWM -> 75% Fan Speed
100% PWM -> 100% Fan Speed
This was with 8 fans per pwm header on my Aquaero's. The more fans per channel, the worse it gets.
After much troubleshooting and many forum posts, it became clear that Noctua was the issue. The Aquacomputer folks recommended using another fan brand, and mentioned they had good luck with Arctic. so I ordered all Arctiv P12 and P14 fans instead, and they indeed did work as expected with fan control, but their peak performance wasn't as good.
After communicating with Noctua, they actually offered to take all the fans back and replace them with older revision fans that didn't have this problem, which I took them up on, and in my next refresh of the system I put all Noctua fans back in.
This experience soured me a little on Noctua fans to be honest (though their customer service was absolutely excellent) and I ahve been researching alternate fans to use for future builds ever since.
Either way, it seems like no one else makes a decent 200mm fan with PWM control, and Watercool specifically recommends using Noctua's 200mm with these radiators, so that's what I am going to do.
