Bio-Hazard
- Jun 8, 2004
Swiftech has released their new GPU block today, externally it looks pretty much the same as the old block, but internally is lots different........
http://www.swiftnets.com/products/mcw55.asp
http://www.swiftnets.com/products/mcw55.asp#fittings
The MCW55 waterblock inherits some characteristics from its predecessor the MCW50, such as the use of built-in quick-connect fittings and the same outer dimensions, but it also features several major enhancements:
Performance is significantly improved thanks to a complete redesign of the internal hydraulics which result in lower processor temperatures (and better overclocks) than the MCW50.
The housing is now made out of Delrin as opposed to Aluminum for prolonged durability.
The seal between housing and copper base plate is an O-ring for superior reliability.
Improved and more reliable mounting system for nVidia based platforms.
In its black and chrome trim, the MCW55 VGA cooler is a perfect match to complement either the MCW6000 or STORM CPU water-blocks.
Major features summary:
Extreme performance:
Optimized hydraulics improve GPU heat dissipation with minor impact on system flow rate in liquid cooling systems powered by high-head capability pumps such as the MCP350 and MCP655 pumps.
1/2" quick-connect fittings provide optimal flow rate in 3/8" systems, and perform on par with traditional 1/2" barb fittings with the optional tube-to-barb adapters
Diamond-Pin Matrix© copper base plate for optimal heat transfer, and turbulent flow
